![]() | Home > Maintenance & Mods (L322) > Battery Replacement 2011 TDV8 4.4 |
| pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1032
spot on - thanks to OP |
| RobsterPC Member Since: 14 Oct 2024 Location: Kent Posts: 147
Quick note from when I did mine, I didn't undo the security bolts, I simply undid the plastic clips that retain the ECU cable and then, after undoing the single 10mm nut, was able to fold the ECU out of the way safely. No need for special pentalobe bits etc. |
I have replaced both those pesky TS25 bolts with simple 10mm bolts ( both for me and future owners of my car ) |
| LukeKnott Member Since: 22 Apr 2024 Location: Warwick Posts: 6
Hi guys,
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3404
Do you actualy need one? I took mine off when I replaced my battery 3 years ago and didn't see the point in putting it back on. 2012 TDV8 Vogue (L322) |
Just nice to have all the pieces of the puzzle! I think it just gives the ecu a bit of support at the top, rather than just hanging off the one nut at the bottom.You up for parting ways with yours?😂 |
| CaifanSC Member Since: 25 Dec 2018 Location: Maryland Posts: 36
Does anyone have the part number for the thin plastic strap that attaches the orange cap for the positive battery terminal to the alternator cable? My orange cap has seen better days, I bought the cap but I can't find the PN for the black thin strap. I have a feeling that's going to break once I start fiddling with the battery. 2012 Range Rover Autobiography
| MilesBFree Member Since: 07 Nov 2023 Location: SC Posts: 33
| JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 310
Changed mine today - biggest tip I can pass on is to use a mini step ladder with a towel between the wing and the step ladder. Also be careful that the step ladder doesn't slide to the side from under you...
| All times are GMT |
