![]() | Home > Maintenance & Mods (L322) > A couple of ride height sensor questions |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8820 ![]() ![]() ![]() |
It can't go too high, it has it's limits which ensure no damage to components...
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766 ![]() ![]() ![]() |
Thanks Pete
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1015 ![]() ![]() ![]() |
You can try two things with IID - it may reset and get you back to normal heights
Thanks pcourtney - I'll go through the guided calibration once its down on firm ground again. Going to replace all 4 height sensors while its in the air.
Update all (and a plea for help) |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35856 ![]() ![]() |
from memory i pressed the dash access switch for around 20 seconds and mine came down from extended.. ... - .- -.
Thanks Stan I’ll try it soon as I’m home. Do you mean the middle ‘lock’ button, or hold the toggle in the lower position? |
Tried both but still stuck up in the clouds |
I take it you have tried a battery disconnection...?
You can see these in RLM - Suspension Go to "Live Values" RLM-Suspension The select ( the option changes colour to green ) Front Left Height Sensor - Voltage (V) Front Left Height Sensor Supply ( V ) Front Right Height Sensor - Voltage (V) Front Right Height Sensor Supply ( V ) Rear Left Height Sensor - Voltage (V) Rear Left Height Sensor Supply ( V ) Rear Right Height Sensor - Voltage (V) Rear Right Height Sensor Supply ( V ) |
Those readings are a bit misleading, according to Patrick ( at GAP ) it's just an arbitrary constant and does not refer to the actual height measurement. NB I had to check myself what "arbitrary constant" means An Arbitrary Constant is a placeholder used in Mathematical Expressions to represent a Value that can be freely chosen, often appearing in Solutions to differential equations or Indefinite Integrals. It allows for the Generalization of solutions, ensuring they encompass all possible specific cases by accounting for "Initial Conditions" or "Boundary Values" that can alter the outcome.
