![]() | Home > Technical (L322) > Welding repair monocoque body shell? |
Happydaze Member Since: 30 Aug 2021 Location: Wirral Posts: 104 ![]() ![]() ![]() |
I dont think it's illegal, yet, to make such repairs! I hope it remains that way too, but there is some doubt over the future, ref the 2024 dvla call for evidence! If you can do the other bits I can't see why you'd be doubtful of these bits though. Cut the rot out fully to solid steel and replace with same gauge steel, properly welded, non of that buzz, buzz, buzz continuous tacking |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
No reason why it can't be repaired. Just look at the likes of Matt Armstrong and the repairs he does to properly crash damaged vehicles and bodywork.
kirk05 Member Since: 25 Jul 2018 Location: Aberdeenshire Posts: 14 ![]() ![]() ![]() |
Thanks...
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8746 ![]() ![]() ![]() |
Just don't cut ALL the rot out in one go, do it in sections, if you cut out that box section and the inner sills you might have problems with body sag....
Cheers...ah see what you mean, i guess cutting out and welding in box-section, say in 300-500mm lengths at a time should keep it strong enough? ok so might have to weld repair the rear sills on both sides first so it keeps some stiffness for cutting out those beam sections... |
Thanks Haylands just seen your project, nice one!! To do this welding i need done on those chassis beams would you recommend stripping the inside out (taking seats & all out) before staring?...was it a difficult job to take the interior out cheers |
Personally I'd take the carpet out, it's not a hard job, just takes some time...
I think the welding element if the repair is not for a novice or well out of practice welder. Having said that I expect there might not be that much welding!
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16394 ![]() ![]() ![]() |
One has to ask if its viable to save? Ill guarantee the rust will be 200% worse than what you see in those images! Once you've started, I suspect you'll be chasing your tail around many many more areas of corrosion before your finished! There can't be a lot of value left in a car of that age either, so is it not worth buying a good (southern) car without the rust problems you see in Aberdeen cars?
