Home > Maintenance & Mods (L405) > Major service/fluids change
Flyboy0902
United Kingdom 2015 Range Rover Autobiography SDV8 Santorini Black
Hi,
Below are a list of things I want to do as part of the service on my car.
Would very much appreciate if if you L405 boffins could take a look and let me know if there's anything I've missed off.. Thanks in advance.. Thumbs Up
-Check condition and security of seats and seat belts.
-Check operation of all lamps, horns and warning indicators.
-Check operation of Windshield and headlight wipers and washer jets.
-Select the LOW range gears and drive the vehicle 3 to 4 vehicle lengths then re-select HIGH range gears.
-Renew pollen filter.
-Check tire pressures, condition, tread depth, signs of uneven wear and suitability (including spare).
-Remove road wheels. Inspect brake pads for wear, calipers for leaks and disks for condition.
-Renew fuel filter element.
-Refit road wheels to opposite sides of the same axle (Use anti-seize compound on spigot bore).
-Check operation of door locks, hinges, door checks, bonnet catch and fuel flap.
-Check torque of towbar fixings.
-Replace the air cleaner elements.
-Check/top-up brake fluid level
-Check/top up Dynamic Response fluid level. Flush system when possible
-Check/top up screen washer reservoir
-Renew engine oil, filter and sump plug/O ring
-Check for debris from auxiliary oil cooler and radiator.
-Check for free play in all suspension and body mounting rubbers.
-Check ball joints anchors, steering system tie rods.
-Check the condition of the ball joints and protective boots. (See MOT write up)
-Check visually brake servo hose, brake, fuel and PAS pipes, unions and electrical harnesses for chafing, leaks and corrosion.
-Check for fluid leaks.
-Check exhaust system for leaks, security and damage.
-Check steering rod ball joint fixings and condition of ball joints, dust covers and EPAS water drain valve.
-Renew transfer box oil.
-Renew locking differential oil. Front
-Renew locking differential oil. Back
-Renew transmission oil and sump
-Fix under car rattle
-Review/fix/replace parking brake release actuator
-Check batteries
-Carry out road test
-Reset service indicator
-Reset engine oil level indicator
Post #714045 14th Mar 2025 5:51pm
Gremlin500
Land Rover 169 point Checklist:
Thumbs Up V6 Vogue - “Less is More” - less to go wrong!
Post #714059 14th Mar 2025 7:54pm
L405 service sheets..
I think you have pretty Much covered it.
https://www.fullfatrr.com/gallery/albums/u...sheets.pdf There is nothing that can't be fixed with a hammer😜😜
Post #714077 14th Mar 2025 11:14pm
