Home > Technical (L322) > EAS Fault - 0x7A Reservoir Pressure rises when lifting
jamiej
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Hi all,
My 2003 M62 L322 has a new fault. Yippee!
I have the Air Suspension warning, but apart from that, all seems well.
The fault first tripped when going on the motorway and the car tried to get into "Motorway mode" and lower itself.
The car sits quite happily (i.e. no sagging), but it is perhaps a little uneven (it may have always been, doesn't really bother me).
Anyway, the GapIID tool has shown the fault
... which google seems to have no answers for.
If it makes any difference, i also have a 0x10 Steering angle sensor watchdog error
So anyone have any ideas?
Be nice to have a clear dash, it used to be free of any errors Sad
Apart from that, all is well in the land of old L322s (as well as they can be!)
Many thanks all.
Post #714049 14th Mar 2025 6:13pm
Gsxr1250dave
Have you drilled a hole in the filter on the air pump yet ? If not do it.
Post #714069 14th Mar 2025 9:47pm
RogueRanger
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
That style of code seems to come and go all the time. I don’t think they are actually fault codes and that may be why you’re not finding anything on Google.
What is the exact message you’re seeing on the dash? Des
2005 (2006 MY) L322 4.2sc Java Black, 2010 facelift conversion
1965 Lenham Lemans GT 1310 , Gulf Racing blue, FIA spec and road legal
2018 F56 Mini JCW, Thunder Grey/Black, Mulgari St2 tuned, FMIC, short shifter and Eibach springs
Post #714079 15th Mar 2025 12:07am
jamiej
Thank you.
The cone filter. Can I just whip that out or do I need to worry about the 100+ psi air pressure in the compressor.
The dash error is > AIR SUSP. INACTIVE < and the EAS won’t change its setting, although the light on the EAS control is illuminated and looks as it should.
Post #714142 15th Mar 2025 9:17pm
Gsxr1250dave
Yes you can just remove the cone filter from the pump
Post #714144 15th Mar 2025 9:50pm
dingg1
Yeah, if you resort to drilling a hole in it, just remove it and throw it away, it basically the same thing 👍😎
Post #714149 15th Mar 2025 10:49pm
IIRC this is a "hard" fault, it will not clear when you have rectified the problem.
It will need a diagnostic tool to erase... Thumbs Up Pete
Post #714151 15th Mar 2025 11:52pm
jamiej
Hmmm.
So I whipped the air compressor out and it’s a Wabco one. Unsure if that the original one or not but it’s very clean. I guess it lives in a nice clean space but it was very clean for something potentially 20 years old.
The exhaust looks to have already been removed Sad
I cleared the codes on my GapIID but the moment I started the car, the same Air Susp Inactive came back. Sad
Any other ideas?
Post #714324 18th Mar 2025 11:12am
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
I too am having a headaches worth of EAS faults at the moment on my 2003 TD6 Big Cry so I feel your pain.
If you have a steering angle sensor fault, on your iiD go into ‘live values’ and make sure you’re getting a reading from the SAS, turn the wheel and see if the angle (degrees) updates.
I had a few previous EAS faults that traced back to a faulty SAS sensor, I’ve just replaced it and all the original suspension faults have gone. There are small metal contacts in the sensor that read its value, so the usual full lock left, full lock right to reset faults doesn’t work. Couple of YouTube videos explain it and how to change it, the guy is called GrooveOn I think.
Change the SAS sensor and see how you go, it’s best if you know a 3’9” midget with t-Rex arms to ask to change it, or a contortionist
SAS sensor is the same as in 5 series and X5’s I think, mine was about £65 on eBay
Post #714503 20th Mar 2025 5:12pm
