Home > Technical (L322) > TDV8 4.4 fuel tank capacity? |
p-trax Member Since: 30 Dec 2010 Location: Hertfordshire Posts: 261 |
I stuck 95 litres in yesterday, and it wasn't exactly running on fumes when I stopped off at the garage! Gerry
5th Jul 2011 9:16pm |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 |
Are all FFRR's fitted with the same size fuel tank?
5th Jul 2011 9:25pm |
jonminns Member Since: 07 Mar 2011 Location: Leicestershire, UK Posts: 155 |
Diesels self-prime these days, no need to worry about that
5th Jul 2011 10:11pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
That's excellent, and about time! When did they start self priming? After the TD6 I take it? |
6th Jul 2011 9:29am |
I had a van made in 2002 which self-primed! The TD6 engine was reasonably old when it found its way into the Range Rover though 2008/58 FFRR 3.6 TDV8 Vogue |
6th Jul 2011 12:39pm |
Avi Member Since: 24 Sep 2010 Location: North West Posts: 309 |
Also, make sure you never go off road or over any bumps, as this may shake the crap up from the bottom of the tank. |
6th Jul 2011 1:22pm |
Baben Member Since: 17 Oct 2010 Location: Kyalami Posts: 165 |
Not sure all diesels self-prime. At least the TDV6 in the D3 doesn't. Before you take that trip with the Jerrycans make sure you know where the air bleed is and what the priming sequence is.
6th Jul 2011 5:43pm |
