Home > Technical (L322) > It's too hot in here. Climate control problems.
FJ12Jagmen
United Kingdom 2007 Range Rover Vogue TDV8 Santorini Black
Whilst returning from up North recently, a 250 mile journey, I noticed that I was getting progressively hotter despite turning down the temperature. The trim panel (‘floor console extension’ from the WM) near my left leg was hot to touch. No smells so I didn’t think the car was on fire. Pulled on the drive and on extracting the ignition key noticed the blade was uncomfortably hot to touch.
Quite glad there wasn’t a pile of ash on the drive the next day. Tried to replicate the problem but didn’t have time to drive around for an hour. Did take the trim panel off but could see nothing obvious. No fault codes on GAP IID, usual ‘clutch compressor off’ but it wasn’t.
A few days later I dug around the forum and the WM then went for a drive. When fully warmed up started playing with the heater. Found that I could increase and decrease the cabin temperature by using the extreme settings. Concluded that the coolant valves were working (replaced last year). Using the face vents managed to determine that the passenger side was performing as instructed but the drivers side was ‘lazy’ and generally hotter. I suspected a sensor fault.
Back on the drive I got the kitchen thermometer and checked the temps at the face level outlets.
With standard settings, 22 on both temp settings and the wheel on hot you can see I was getting 56°C at the drivers vent.
Moving the wheel to full blue had a dramatic effect on the drivers side. Passenger side was behaving normally.
Back to the WM and the Control Panel for the ATC (Climate control).
Inputs
The system receives ambient temperature, engine coolant temperature, engine speed and vehicle speed inputs in K bus messages from the instrument cluster. If the K bus messages are missing or faulty, the ATC module adopts the following default values: (standard values). If a fault develops in the input from the temperature selector switch on the control panel, the ATC module adopts a default value of 22 °C (72 °F).’
No faults on the instrument cluster and all looks normal.
IN-VEHICLE TEMPERATURE SENSOR – This is in the control panel behind a little grill. I had had control box out about 6 months ago when the air con seemed to be playing up. Dismantled and miffed to find no dust, debris etc. A disappointingly clean unit. I didn’t think it would be that and it defaults to 20 °C.
REFRIGERANT PRESSURE SENSOR disengages the air con clutch if there’s a problem.
EVAPORATOR TEMPERATURE SENSOR defaults to 32°C if there’s a fault.
HEATER TEMPERATURE SENSOR defaults to 55 °C (131 °F). That could be the problem but where is it.
After looking at myriad line drawings with vague arrows and nothing in the WM about replacement - ‘Two sensors are installed, one each side of the vehicle center-line.’ Brilliant.
Indebted to Highroller who actually took his out and provided a photo.It’s such a relief when someone has been there before and documented it (hence why I’m doing this).
Removed the floor console extensions and pulled the climate control assembly out. Removing the 5 block connectors was a pain but gets the unit out of the way.
The heater temperature sensors are attached to the two white block connectors either side of the vehicle center line. Removal of those was fiddly and it’s not obvious how the sensors come out. From Highrollers picture the opening is circular with a cut out. Thought it would be the usual 90 or 180 ° turn to release. Nope, straight pull, a little bit tight but fine. I marked the left one with masking tape so I wouldn’t get confused.
Nothing obviously wrong with either one. They are NTC Thermistors and from what I’ve read are supplied with a constant current, as they heat up their resistance changes and this is used to control other bits of kit. I set up a test rig. Don’t judge, its freezing out there and the Mrs wants the windows cleaned.
Multimeter on Ohms, kitchen thermometer, I used a hair drier to provide heat and noted the results.
This appears to show that the right sensor loses resistance rapidly between 20 and 30 but is not a million miles away at the higher temperatures. I thought I would get a much greater discrepancy or the right one would be completely foobarred. I suppose it’s usual working range is between 15 ° and 28 °, so the upper temps shouldn’t matter. This being the case my multimeter is not sensitive enough to really show accurate results in that range. I also concluded that the kitchen thermometer does not react quick enough to the heat from the hairdryer.
Changed the setup. I used a water bath (wifes favorite cereal bowl) ice and hot water from the kettle. Taped the thermometer to the side with the probe in the bottom of the bowl, could then position the sensor head directly over it. This was a much slower but far more controllable method. Started with cold water and a couple of ice cubes, removing them when the temp got down to 10 °. Took a reading and added hot water. Found I could slowly bring the temperature up, and back down, to get accurate measurements.
Aaaargh. This shows they are both performing the same. Are they both broken now? If not then is the issue in the control module? Or is it something else entirely.
I’ve ordered a used sensor from ebay - £18 instead of £90 if you can find one. I may be chasing my tail because this is obviously an intermittent fault – air con problems in the summer, then performed fine, now heater problems.
Meanwhile I’ll swap them over on replacement and see if the wife gets cooked.
I read more of the WM than is probably healthy! Also saw that the ATC (Climate control box) controls the heated washer jets. Driving on the A702 from Edinburgh to the A74 in January the outside temp got down to -5 ° and my washers froze. With salt all over the screen and a low sun it was not good. Flask of hot water sorted them out and they haven’t been tested since. Control module problem? Earth issue? Gremlins?
Ebay sensor arrived and I retested all the sensors. Used excel and my very basic skills with it to produce a graph.
Dark blue line is temperature, dotted lines are the sensors.
All performed pretty much the same!
Changed the blower motor and FSR. Thats a very small, sentence for a bit of a job. Blower started squeeking last year which I treated with a squirt of oil through the plenum. I bought another one which has sat on the bench ever since.
I wrote all that several weeks ago then life got in the way and more motorway trips.
To my delight the new fan has an electric squeal, like a dog whistle, hoping it will go away with wear.
Although the fan appeared to be working it seemed sluggish so I changed the FSR to the old one. In doing so and whilst forcing my hand into that narrow gap, the rear fan burst into life at full bore??? The dial was turned right down and fan still running, pulled the fuse in the rear fuse box and it turned off.
Latest motorway trip – rear heater area was extremely hot to touch. I could control the heat in the front a bit by setting temp very low, wheel on blue and after a while cooler air would flow, the bolster also cooled down. Get too cold, tried minor adjustments but only big movements worked. Couldn’t balance it at all.
I think the heater control valve is working, perhaps not brilliantly, because I can cool down the front.
I'm very confused about the rear which seemed to happen when I was replacing the FSR. Is the wiring in that area related to the rear blower?
If the heater control valve sends coolant to each side, where does the rear get coolant from?
Can anyone tell me where the earth point (K108 I think) is located? It seems to be the earth for most of the units in the dash. Can't see it in the WM.
I'm suspecting the control unit. A couple of weeks ago I noticed the night lights surrounding the knobs etc weren't working. They are now. Also the switch to control the rear heating didn't light up. It does now.
Any help much appreciated. 2007 3.6 TDV8
1979 Mini Special
1988 Yamaha FJ1200
!952 BSA Gold Flash
Post #714296 18th Mar 2025 1:55am
FJ12Jagmen
For completeness I obtained a new seal kit for the original heater control valve which I had kept. Fitting was relatively easy. Then swapped them over.
On taking apart the one I had obtained on ebay was surprised by the different sizes of the valves.
Left is the ebay one, right is original and the ebay one was leaking.
No change, still cooking on a run. 2007 3.6 TDV8
1979 Mini Special
1988 Yamaha FJ1200
!952 BSA Gold Flash
Post #714547 21st Mar 2025 12:47am
FJ12Jagmen
Removed drivers feet warming duct, panel above pedals and console side. The main panel under the steering wheel seems to require removal of the dash so that didn't happen.
Visually checked all the wiring and can't see any issues. Removed the blend motor, marked position of the lever and dismantled it.
No dust or dirt, very disappointing.
Checked operation of the blend flap by turning the slotted end with a screwdriver. Seems very stiff but moves.
Removed the ATC, checked for dust, corrosion etc. All seems good. Used a hair dryer and checked the thermistor.
Resistance changed so I'll take that as good.
Put ATC back in and connected the blend flap motor, it moves when ignition switched on. Re-inserted it and could feel it operating.
Earth point in front of the door and behind the panel next to the accelerator looks very clean and shiny. Still don't know if that is K108. There's one on the passenger side that I will check.
Is the ATC at fault? It is a re-manufactured unit.
Anyone advise on a reliable place to get a new one? 2007 3.6 TDV8
1979 Mini Special
1988 Yamaha FJ1200
!952 BSA Gold Flash
Post #714745 24th Mar 2025 1:04pm
FJ12Jagmen
Think I have 3 issues with this heating system-
1) The heater control valve is lazy. This is the original that I refurbished with new seals and which involved glueing a stainless steel collar to a stainless shaft. I suspect the glue has partially failed.
2) The flap controlling airflow to the rear has failed.
3) The rear blower was on full until I pulled the fuse.
Bought another heater control valve off ebay and fitted it. Can now control the temperature in the cab accurately.
The flap motor appears to be working, I can hear it as soon as I open a door. After a few seconds it stops. It operates on a slot which I can move by hand, its stiff but operates. What I can’t tell is if that slot is still connected to the flap shaft.
Had a go at the rear blower motor today. Checked the fuse (14, 15A in the rear fuse box) and its good. 12v supplied on one side of the fuse.
Removed the relay (number 7), replaced the fuse and found 12v to one of the feeds. Tested the relay, lovely click and 12v at the output blade. Replaced the relay and turned on the ignition, rear blower not blowing. Turned the fan speed to max, button on the ATC for the rear on and front fan operating. Still nothing.
Now turned to the 2006 wiring diagram because I still can’t find one for my 2007MY. The rear seems a similar setup to the front. There is a control module with 5 wires connected to it and a hedgehog heat sink in the airflow through the duct.
Removed the console bin, 2 screws and a tug at the rear of the bin to release the 2 clips. Pulled the wiring to the cigar lighter and removed the box. The FSR for the rear blower is immediately apparent. The five wires attached in 2 rows (3 and 2) are different colours to the wiring diagram but seem to follow the same path. Pulled the connector , not easy to get hold of, sort of have to do it backhand with my left hand whilst facing the windscreen. Checked for voltage at each wire and found a brown one with 12v, middle one of the three. From the diagram it should be green and going to the motor, suspect it’s actually the feed from the relay. No voltage on any other wires.
The FSR is held in with 2 T20 self tapping screws. Very awkward access but managed with a screwbit and a 6mm ratchet spanner. You know the saying ‘A 10 minute job is one threaded bolt away from taking all day’. Don’t drop the spanner or bit, its a long way down with very little access. Fished it back out with a grabber and coat hanger, 2 skinned knuckles and a lot of time.
FSR looked alright, no obvious bulges in the rubbery coating, scorch marks etc. Tried the FSR from the front that I know is good. Still no action from the blower. Decided to put it back together because I didn’t want hot air blowing out of the FSR hole and into the console.
Whilst struggling to get the connector back on, the blower ran very briefly. Started fiddling with the wires suspecting a broken one. If I held the connector at an angle whilst pushing it on I could get the blower working. Whilst holding it at an odd angle I operated the rear heat switch of the ATC and it worked correctly. Inspected the wires and connecter but could find nothing amiss. Put it back together and everything works fine! Think I’ll be back here in the future.
Still don’t know what to do with the blend flap. Don’t fancy removing the whole heater box. And don’t know how to access or test it. Any ideas? 2007 3.6 TDV8
1979 Mini Special
1988 Yamaha FJ1200
!952 BSA Gold Flash
Post #715026 28th Mar 2025 1:05am
