Home > Technical (L322) > Fill plug gm box 03-TD6 :censored:
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
Mate was changing the gearbox fluid in his 03-TD6,he loosened the fill plug and then proceeded to open up the drain plug to drain and take the sump off to change filter,etc.
After draining and putting filter/sump back on he proceeded to take the fill plug out but the previous person that serviced the g/box Censored the plug when he put it back on. It wont come off.
Any suggestions on how to get the bolt out without Censored up the already Censored thread.
Then what would be the best way forward to get new bolt in without further Censored up the thread anymore.
Any help greatly appreciated.
littecub
Post #714220 17th Mar 2025 10:00am
stuart_2006
If you mean that the hex head of the fill plug has rounded off, I used a 17mm Irwin bolt extractor to remove mine.
Post #714277 17th Mar 2025 9:55pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
There are kits available to repair, here’s a link to one on a popular auction site…
https://www.ebay.co.uk/itm/183101645081?mk...media=COPY
Thumbs Up ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #714308 18th Mar 2025 9:21am
Looks like the filler plug will be a bit hard to reach, he may have to drop the box etc to gain access... Also you will need the sump off to clear swarf from recutting the threads, all in all not a quick or easy job...
 Pete
-Click here for Thread-
Post #714311 18th Mar 2025 9:45am
UK Marine
Thanks Pete I see what you mean….not easy at all. ______________________________
Simon
Post #714312 18th Mar 2025 9:59am
Excellent for the drain plug which is the most commonly abused one...
Never seen that kit before, mind you, luckily never had a problem with a drain plug... Thumbs Up Pete
Post #714315 18th Mar 2025 10:07am
UK Marine
Simon
Post #714316 18th Mar 2025 10:18am
littlecub
Thanks for the extra tips on how to get the Censored hex off guys, much appreciated.
littlecub
Post #714373 18th Mar 2025 10:13pm
