Home > Technical (L322) > 2012 4.4 TDV8 exhaust hanger mount L bracket search
dmc567
Hi guys,
I've recently purchased a 2012 Westminster 4.4 TDV8 and found a few issues I'm working through.
I discovered the backbox and exhaust could have come off at any moment when I noticed it hanging low to the ground. I found that the L brackets that hold the hangers WCU500270 & WCU500260 had snapped off completely and one has been poorly welded back and had zip ties holding it together. Rather dangerous behaviour by the previous owner, how it passed an MOT 6 months ago is beyond me.
I have ordered the two new hangers, part numbers above, but I have been unable to find the part numbers for the L brackets that bolt these to the frame of the vehicle. Does anyone have any idea of what the part number is? I am considering just a generic L bracket that will hold the bolts firmly could be the solution if there isn't a JLR or aftermarket part I can find.
Any suggestions are welcomed.
Post #714534 20th Mar 2025 10:01pm
Happydaze
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Looks like a simple repair for someone who can weld. It needs to come off to be done properly.
Alternatively, it looks simple enough to remake with some flatbar, which wouldn't require welding.
To replace with something generic might be difficult as the spacing of the 2 bolts is important, but not absolutely critical.
Chris
Post #714542 20th Mar 2025 11:38pm
