![]() | Home > My Range Rover > First time owner |
Andyyav Member Since: 13 Mar 2017 Location: Norfolk Posts: 235 ![]() ![]() ![]() |
Welcome!
Eugov Member Since: 15 Mar 2025 Location: Lancashire Posts: 26 ![]() ![]() ![]() |
Yes it does have the FBH. I don’t have the fob but can set it up timed to come on. Does the heater make a humming noise from the passenger footwell area? As I could hear this as I was driving this morning for the first 10-15 min. 2011 Vogue 4.4 TDV8 Orkney Grey |
That sounds about right 1972 Series 3 full of character
Eastsoutheast Member Since: 10 Jan 2023 Location: Wimblington Posts: 207 ![]() ![]() ![]() |
I also have a late L322 4.4 TDV8 Vogue with some great options, awesome cars. Mine warms up within 5 to 10 mins max and that's being driven very gently which I do until it's fully warmed.
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 569 ![]() ![]() ![]() |
Being gluttons for punishment we have two 4.4 TdV8's. They both drive pretty much the same (as you'd expect). Warm up is pretty good even on a very cold morning, but step off from a standing start is always a bit 'hit the throttle, wait half a second, GO." Drives:
Shaun_ Member Since: 02 Feb 2017 Location: New Forest Posts: 92 ![]() ![]() ![]() |
I'm with Eastsoutheast... my 2012 Westminster warms up very quickly even on really cold mornings. I would say the gauge reaches vertical after less than 10 minutes. If it's really chilly I can hear the pump ticking away under the boot for the FBH. This is automatic - you don't have to use the fob or timed climate from the screen - they're only used if you want to pre-heat the cabin.
