Home > Technical (L322) > Tdv8 4.4 restricted performance diagnosis
Monty400k
Scotland 2002 Range Rover SE Td6 Zermatt Silver
Having ongoing restricted performance issue with my 2012, I checked all the usual culprits but made no difference, gave in and took it to an independent and based on the codes they are saying its a wiring fault. The car snapped the aux belt just before I bought it so I now suspect the flailing belt has damaged wiring to the cross over valve, has anyone had a similar issue, I am looking for ways to test/diagnose the wiring, was booked back in to the independent however they forgot to add my booking to their diary and completely wasted my time.
Alternatively can anyone recommend a good independent in the Glasgow area, not Elite in Clydebank, and ES alternators in Kirkintilloch are being non committal also.
Post #714605 22nd Mar 2025 10:15am
Baltic Blue
If the CSOV isn’t opening Iwould be looking for damage on the vacuum pipes, not a wiring problem?
Cheers
Post #714611 22nd Mar 2025 11:59am
Monty400k
I've been through the vaccuam system, found some collapsed lines which I replaced, independent specialist claim that the fault code point towards an electrical fault, they weren't aware of the belt failure so have no reason to doubt them. Smoke test would be the only way to definitely check vaccuam system I assume?
Post #714614 22nd Mar 2025 12:22pm
toby1
Do you have the fault code(s)? 2012 Vogue TDV8 in Aintree green over sand
Post #714616 22nd Mar 2025 12:42pm
Monty400k
P0033-00
P004b-71
P004c-77
Inlet elbow has been off, cleaned and sealed with o rings, 4 rubber hoses checked, vacuum pipes replaced where nesesary, cross over valve arm moves freely and wiring appears to be intact. Is there a check I can carry out on the connector to the cross over valve, voltage/continuity etc?
Post #714651 23rd Mar 2025 11:45am
Baltic Blue
I also had PO33-00 (2F) code showing for ages before I found the cause to be a dislodged plug on the wiring.
I did a write up, but can’t find the post this morning, sorry, I will keep searching.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #714654 23rd Mar 2025 12:02pm
Monty400k
I've read your thread, the plug is connected, although I suspect that is the connector with the damaged wire due to its location in relation to the belt, if I could test the connector for voltage etc it means I could rule it out
Post #714657 23rd Mar 2025 12:46pm
Baltic Blue
Cheers, I will just add, even with the plug disconnected it definitely didn’t cause any R P problems.
Post #714658 23rd Mar 2025 12:51pm
Monty400k
Good to know, thanks
Post #714661 23rd Mar 2025 1:41pm
