![]() | Home > Technical (L405) > Myriad of lights on dashboard appeared . ABS, HDC etc |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 537 ![]() ![]() |
Sounds to me like the wheel sensor will most likely be the fault. It'll throw up all the warnings you have seen (although not sure about the park brake one!).
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
welcome to the forum. |
bud Member Since: 23 Mar 2025 Location: Staffordshire Posts: 7 ![]() ![]() |
No wheel bearing rumbles, vehicle drives beautifully. Park brake fully functional. Its got 101k on the clock and iam the 3rd owner. |
I had been for a descent drive prior to plugging it in so I wouldve thought the battery would be good, however now you mention it SSD had the battery symbol in Yellow. Thanks for the welcome ![]() |
Probably not bearing relateed then.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6819 ![]() ![]() ![]() |
I had to replace a rear wheel sensor a few weeks ago for these very symptoms. My first thoughts were that it was the battery, which I replaced as it was still on its original but it didn’t fix it. I also checked the earth point but they were also fine.
Ah thanks for that, really good to know Iam in the right area.
hmallett Member Since: 21 Jan 2024 Location: Mid-Wales Posts: 130 ![]() ![]() ![]() |
So many of the systems rely on data from the ABS module that I agree that a faulty wheel speed sensor could generate all those faults (I have seen similar on my Discovery 3). The park brake module uses wheel speed data to know what mode it should engage the park brake with, so to me, it makes sense that you would get a park brake error too. |
Oh yes of course! ![]() ![]() Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
Matt Buckland Member Since: 27 Nov 2018 Location: Derbyshire Posts: 79 ![]() ![]() ![]() |
Another vote for ABS sensor.
Ok, so I have replaced the sensor now.
UPDATE:
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 388 ![]() ![]() ![]() |
Appreciate you're getting aspecific DTC for a WSS, but if you haven't already, it would be worth it to check the earthing stud under the front offside arch liner as I have had this on 2 vehicles now, on my L405 it was very strange, adaptive cruise control would cancel randomly due to a loss of comms with the ABS module, but only when the lights were on.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1847 ![]() ![]() |
