![]() | Home > Technical (L322) > 2011 4.4 TDV8 turbo spool sound on cold start |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35856 ![]() ![]() |
fuel burning heater ? ... - .- -.
Benfelrr Member Since: 27 May 2012 Location: Wiltshire Posts: 301 ![]() ![]() ![]() |
Ahhhh. I had not thought of that, thanks |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
The FBH is located in the front passenger wheel arch, sort of under the battery but in the wheel well. Its exhaust is down near where the front mudflap would go. Sounds a bit like a jet aircraft when it starts up….. should help you narrow it down. Heard better outside the car.
Ah thanks. Yes hopefully it is that. No turbo sounds out of the exhaust so guessing it is that. Many thanks. It is certainly working. 2011 Range Rover Vogue 4.4 TDV8
