Home > Technical (L405) > Top glove box - what is it meant to do?
Mmarksx19
United Kingdom 2013 Range Rover Autobiography SDV8 Nara Bronze
The top glove box on my 2013 L405 is not working how I expected it to.
It's been like this since I bought the car so I don't know how it's meant to work.
If I press the top part of the button to open it, nothing happens. If I press the top part and pull the door down at the same time, it opens but it doesn't stay open, the second I let go of the door, it closes again.
What is it meant to do and, if this isn't normal, where do I start looking to fix it?
Thanks, Mike
Post #714738 24th Mar 2025 11:58am
the button press unlocks it...its spring loaded ,you then pull down to access , slam to shut. ... - .- -.
Post #714740 24th Mar 2025 12:47pm
Mmarksx19
So it's meant to stay open? Mine doesn't.
Post #714741 24th Mar 2025 12:49pm
goldeneye32
United Kingdom 2014 Range Rover Autobiography SDV8 Firenze Red
They don't stay open, the button arrow for the top just releases it from the latch, and you have to keep pressure on it to hold it down, it's this way so that it can't stay down when travelling (if you were involved in an accident, the passenger would sustain severe injuries).
to latch it closed just push it hard until you can't pull it open. (which can also be locked if I am correct, when using Valet Park on the screen)
Post #714747 24th Mar 2025 1:31pm
Totally normal, the only thing I find it useful for is a Gap IID, in it's box, fits perfectly, and the pen holder is handy. Rolling Eyes
The bottom glovebox should be damped when it opens, the little thingamebob that does the damping fails quite frequently so I hear... Pete
Post #714748 24th Mar 2025 1:42pm
Mmarksx19
Thank you all so much. So it's working as intended!
It seems weird but I understand the logic.
The bottom glovebox is indeed damped.
Post #714752 24th Mar 2025 2:03pm
goldeneye32
Sadly, my bottom glovebox, doesn't work as intended, and smash's my other half on the knee when she opens it, could be worse............could be my knee!
Post #714760 24th Mar 2025 2:25pm
can you tell me that 'fix' for the knee cruncher please....i do like to annoy my wife as much as possible.. Laughing ... - .- -.
Post #714770 24th Mar 2025 3:11pm
goldeneye32
There's an elastic type band at the rear, cut that and she'll squeale like Gazza in the Spurs Arsenal Semi Final when he was tackled, might also need a cruciate replacement though!
Post #714812 24th Mar 2025 9:19pm
Laughing Thumbs Up ... - .- -.
Post #714813 24th Mar 2025 10:02pm
