![]() | Home > Technical (L322) > Water in spare wheel well |
Tiprat Member Since: 05 Aug 2021 Location: Manchester Posts: 100 ![]() ![]() ![]() |
I had similar problems when I first got our RR, I eventually tracked it down to the water seal around the whole hatch. It was getting under the metal that holds it onto the thin metal surround. The quick cost effective solution for my issue was to get some "gutter sealant" from any of the many sources ie eBay Screwfix ect ect apply the seal into the recess of the boot seal and reseat it all the way round applying even pressure, then where the two ends meet I added a bit more just to make a water tight seal, that was at least 4 years ago and I have never had another leak.
WheelNut Member Since: 30 Jan 2025 Location: Vancouver, Canada Posts: 22 ![]() ![]() ![]() |
I like the idea. I’ll give it a go and see if it works. Nothing to lose really. 2006 Range Rover 4.4L Gas
jamiej Member Since: 01 Dec 2023 Location: Surrey Posts: 59 ![]() ![]() ![]() |
Have you checked that the leak is not from the rear wash jet? |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3233 ![]() ![]() ![]() |
mine is similar vintage and it was the welds by the upper hinges.
I'm getting water in the rear even when I don't drive the RR. The water in the tire well doesn't feel soapy or anything either. 2006 Range Rover 4.4L Gas 2006 BMW 330i 6MT 2024 Mazda CX-5 |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 339 ![]() ![]() |
1) Fit new tailgate aperture rubber. Ensure to fit it accurately - there is a variation in density where the lower tailgate closes. Make sure to get it right the first time. Using silicon on an old rubber doesn't work. They often leak along the top where they stop sealing, then the water runs down the inside... and ends up in the wheel well. New ones come full of putty. run your hands along the whole thing and find the side bits.
Update: I added some window sealer (seems like mastic type goo) to the rear channel of the hatch seal (#6 in the diagram in my first post). This ensured no water was sneaking behind the seal and getting into the body seam. I also added a heavy layer of silicone oil to the sealing surface of #6 and #7. The boot is now dry and has survived a number of heavy rains with no leaks. The silicone oil seems to have rejuvenated the rubber material somewhat. I'd say that a failed #6 hatch seal was the culprit. I considered replacing the whole #6 seal, but it costs nearly $300CDN with shipping and tax, so I figured I'd use what I had in the garage to get me by for now. I'll see if the leak returns with the heavy rain this fall and if it does I will replace the seal and put this to rest, but for now it is working. 2006 Range Rover 4.4L Gas
Fits Member Since: 04 May 2025 Location: Leipzig Posts: 1 ![]() ![]() |
In my case, it was the right adjusting screw of the upper tailgate. Apply some sealant to the thread. |
