Home > Technical (L322) > Park brake fault.
Armitage
Ireland 2008 Range Rover Vogue TDV8 Rimini Red
Park brake fault.
I have a Park brake fault dash warning and a constant amber warning light.
Electric park brake seems to work fine. Diagnostic tool reveals the following:
C1A48-01 - Warning lamp circuit, signal lamp connection failure - General failure information - general electrical failure (2B)
This won't clear.
I've disconnected the epb module and sprayed contact cleaner on the connector, to no avail.
I've done some searching on this topic but found nothing related to the L322 (Tdv8 3.6 2007).
Anyone come across something similar and find a solution?
Post #712792 25th Feb 2025 8:11pm
Proftinkerpot
Northern Ireland 2012 Range Rover Westminster TDV8 Stornoway Grey
Warning lamp failure makes me think its not the actual operation of the park brake but rather the electric circuit that activates the handbrake indicator on the dash. Is the light coming on and going off as it should? I suspect an issue at the park brake itself related to the wiring such as a corroded connector.
Post #712898 26th Feb 2025 10:03pm
Armitage
I will try to remove and inspect the loom from the brake module to the left side boot space. The connector did not appear to have any signs of corrosion but it is possible there could have been hidden within the connector.
Failing this, what could my other options be?
Post #712899 26th Feb 2025 10:11pm
Armitage
And yes, the red light goes off when the engine is started/park brake released
Post #712900 26th Feb 2025 10:12pm
Mali
Wales 2003 Range Rover SE Td6 Giverny Green
I don’t suppose you made any headway with this did you?
I have the same fault and I’m struggling to find the problem!
Cheers,
Mart. Current wallet destroyers:
2002 DISCO TD5
2003 TD6 SE
2010 TDV8 VOGUE
Post #714838 25th Mar 2025 8:20am
Armitage
No, not yet. From researching the issue, I found some similar situations of electrical problems caused by corroded connections.
These all point to the large loom that sits on the right side channel beside the driver seat (RHD) above the sill.
Water ingress from the sunroof/leaking windscreen tends to pool in that area causing the factory splices to corrode.
However, being a Land Rover, the cause of the electrical problem could be anywhere.
Post #714845 25th Mar 2025 10:11am
Mali
Fair play, cheers for the heads up on some places to look. I will pop it up on the lift this week and look at the condition of the plug going in to the module, then start looking at tracing the loom and checking for breakages. I’ll let you know if I ever find the fault! Current wallet destroyers:
2002 DISCO TD5
2003 TD6 SE
2010 TDV8 VOGUE
Post #714887 25th Mar 2025 9:29pm
Armitage
Best of luck with it and report back if you find anything.
Post #714888 25th Mar 2025 9:32pm
