![]() | Home > Maintenance & Mods (L322) > "CHECK COOLANT LEVEL" - Dashboard warning |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
I recently had mine swapped out for a new Genuine one as old one was just too dirty.
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147 ![]() ![]() ![]() |
Thanks.My bottle is relatively clean but I can't see a float?Seem as I will have to replace. 2012 TDV8 Vogue SE 4.4 |
How do one remove the sensor?Do you loose fluid when you remove the sensor? 2012 TDV8 Vogue SE 4.4 |
LFREE22 Member Since: 25 Apr 2023 Location: Aberdeenshire Posts: 11 ![]() ![]() ![]() |
Is there an easy way to try replacing the sensor without having to do the whole tank?
I ended up replacing the bottle. 2012 TDV8 Vogue SE 4.4 |
Jookul Member Since: 28 Dec 2020 Location: Munster Posts: 11 ![]() ![]() |
So just reviving this thread as my experience with this over the weekend might help. So to cut a long story short, I had to get some work on my cooling system done recently and when I picked up the car there was a low coolant level message showing, though the bottle was full. I drove the car home and started my internet research. Like most people I was thinking bad sensor, dirt on the sensor, etc. and I was looking at replacing the bottle. But part of my research started bringing up the idea of a low coolant concentration bring on the low level warning. and a few You tube clips showed how the float will sink in water and float in a good coolant concentration. So yesterday I took my hydrometer and checked the level of concentration. I was surprised to learn that my concentration was very low, though by looking at the color of the coolant I would not have thought it was as low as it was. So I syphoned off as much as I could from the bottle which left me with about a 2 inch level in the bottom of the bottle. I then refilled the bottle with 1.5 liter of coolant concentrate and when I turned on the ignition. There was no more error, its was cleared.
steve k Member Since: 05 Apr 2024 Location: Berkshire Posts: 62 ![]() ![]() ![]() |
I ended up having to replace my expansion tank after first replacing the reed switch sensor. I did not dismantle/destroy the old tank to see what had happened to the float but strongly suspect that over the years it had accumulated pink crud build up adding weight to the float to the point that it would trigger low level.
