![]() | Home > Maintenance & Mods (L405) > 2020 Deployable step obstruction still after motor change |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 371 ![]() ![]() ![]() |
Is the front bracket moving freely? Maybe worth taking the step off and seeing if there is a difference as the obstruction error is due to motor current draw. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 402 ![]() ![]() |
I've just had the same with mine. They need calibrating after a hinge/motor change.
I changed a rear bracket and motor on my LWB (different bracket to the SWB), neve had to calibrate, maybe I was lucky!! L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
Mine was stuck out the same as Fez's. It's one reason I sourced the motors and hinges in bulk. Mine had both hinges and the motor swapped and it does exactly the same as Fez's now - goes right back in again. The calibration thing I touched on in more detail on this topic the other day.
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 626 ![]() ![]() ![]() |
I'm sure you guys will have tried this....but when mine have gone temperamental one of the things that worked for me was to kneel ready next to the car, open a door and grab/pull the step as it tried to start. If you can manually pull it all the way out with the motor operating, it will generally stay. May also need to be there in a similar postion to be ready to push it back in. The extra manual force keeps the sensor happy - otherwise it reverses as soon as any resistence detected. Getting over the sticky bit is the break-through. Usually only needs two or three of manual assists and a few extra squirts of lube to get it going again on its own. Mike - MPx
fez Member Since: 24 Jan 2025 Location: UK Posts: 11 ![]() ![]() ![]() |
Thanks all,
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3921 ![]() ![]() ![]() |
There's plenty on here who will testify to the fact that I'm no mechanic but are the hinges shoving the steps out in perfect parallel because if not one will pull the other to one side it'll sense a problem and they'll go back in. Although if the steps are removed as above this shouldn't happen anyway.
alaska1993 Member Since: 19 Feb 2025 Location: Brasov Posts: 17 ![]() ![]() ![]() |
When I bought mine recently, I noticed the right one was deploying out but wouldn’t deploy back in. Would get about halfway, then go back out. We put it on the left at the dealer and found a broken bracket. As mentioned, I gave it a nudge to seat all the way back agains the vehicle, then turned them off. The dealer is sending me a new OEM bracket. When it arrives, it may go in the attic. I think I prefer the vehicle without the running boards. |
It hasn't yet. Post here. 2017 4.4 SDV8 Autobiography in black 2018 D300 SE Velar in champagne 1982 Rolls Royce Silver Spirit in green |
