![]() | Home > Technical (L322) > rear light cluster l322 tdv8 4.4 2011 |
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 787 ![]() ![]() ![]() |
The rear light you bought, is it possible it's for the American market? As they have the red side marker illuminated. Where did you buy the rear light from?
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 690 ![]() ![]() ![]() |
Ha, too right, should only ever buy British Made junk |
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 200 ![]() ![]() ![]() |
This comment will not be helpful but I needed to fix a near side brake light failure. Faced with a unit replacement at £400+, £300+ etc. I bought one for £90 and fitted that a year ago and it has worked fine since. New from a eBay supplier and cheaper than getting it serviced at a garage.
tracker Member Since: 22 May 2024 Location: Paphos Posts: 30 ![]() ![]() ![]() |
I replaced one of my rear light assemblies last year for the same reason (side marker was illuminated) as MOT failed the rear lighting. I found out someone had replaced the original with a North American version. I got a new Magneti Marelli, which is OEM, for just under €300. |
