![]() | Home > Technical (L322) > Rear Differential Lock - Probable motor issue |
Crispian22 Member Since: 25 May 2017 Location: Midlands Posts: 144 ![]() ![]() ![]() |
I had to change the motor on my 07 SC last year,it is possible to do it without dropping the diff,the motor is held on by 4 hex bolts,you do have to work blind though as it sits on top of the diff and you have to feel for the bolt position.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1389 ![]() ![]() |
I have an IID and have toyed with the idea of just going into the CCF and changing the setting for rear diff locking to "NOT FITTED". Any thoughts on that as an option?
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 923 ![]() ![]() |
I’ve done this job, see my posts on it here -
RogerL322 Member Since: 12 Aug 2022 Location: Worcester Posts: 15 ![]() ![]() ![]() |
Thanks all! And especially thanks for the info on the fact the motor replacement can be done without dropping the diff despite it being a "pig" of a job.
Carbon Member Since: 30 Mar 2025 Location: SoCal Posts: 2 ![]() ![]() |
So I'm having this issue for the 2nd time now with around 130k miles on our 2008 Full Size Supercharged. We replaced the differential motor in April 2016 at 70k miles and I realize in retrospect we got pretty screwed on the price, but the invoice seems to indicate OEM. Mechanic today is suggesting we don't spend a lot on the motor because it may not totally solve the problem (there was a decent amout of metal in the rear diff fluid when it came out but no chunks). So no point getting a fancy one of these if the diff is dead. Does anyone have a source for one they recommend? Like off a junked L322 or any of these knockoff units that will actually work? I'm seeing LR032711 and LR032712 as part numbers for this thing, but for some reason the sites don't include the 06-09 4.2 Supercharged on that list, though it applies to basically everything else from that era. Any help would be appreciated. OEM cost best I can find is $670.26 if I use the local dealer parts website. Which has great deals on OEM stuff by the way.
Carbon, I can't speak for the US side of the pond, but here in the UK, if you buy an OEM diff motor/gear, it does indeed cost a similar amount. However, if you return the old one you get a £100 refund.
I think the mechanic did a fluid flush and replacement and did the software flash but it didn't solve the problem. It's only when I engage reverse gear that the lights come on and they will typically go back off again when the car is turned off and back on again. |
