Home > Maintenance & Mods (L405) > Adblue injector issues
Afternoon all, I’ve been chasing an intermittent issue with the Adblue system and ‘think” I might have a faulty DEF injector. I’m now seeing the dreaded countdown to not starting message, which I’ve had before but mysteriously disappeared a few times, but now it seems more permanent.
I have loads of the usual DEF type fault codes but I think I have ruled out the following
1. The injector was slightly blocked, so it was cleaned and the problem cleared up for a few weeks.
2. Checked the voltage going to the injector and it seems fine, as broken wires feature a lot in these issues.
My latest test was to see if the injector was working properly by applying 12v to it but there was no “click” as I was expecting, so my current theory is that the DEF injector may have failed completely but having removed it, I noticed that the Adblue feed pipe was totally dry, which surprised me, as I was expecting some residual fluid to be present.
My question is, would a failed injector mean there would be no Adblue fluid in the feeder pipe, or is that more likely to indicate a blockage further back, or even the Adblue pump itself?
Any help or advice gratefully accepted Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #715189 30th Mar 2025 12:44pm
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
Might be of some use?
&ab_channel=O%27RileysAutos
Post #715222 30th Mar 2025 9:33pm
Thanks, I’ve watched a few of his DEF ones but this one is for DPF, which I don’t have any issues with (yet!) Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #715226 30th Mar 2025 10:36pm
baz000000
It does detail a blockage of the AdBlue line at the inlet point into the DPF.
Post #715242 31st Mar 2025 8:56am
Yes, I’ve cleaned out the injector and also the inlet it connects to. It’s wasn’t particularly bad compared to some of the videos I’ve seen on YouTube.
I think my issue now is that there isn’t any Adblue getting to the injector, or if it is, the injector isn’t firing it in to the DPF.
Cheers Got - 2017 SDV8 Autobiography in Loire Blue
Post #715315 31st Mar 2025 11:11pm
Just to finish this thread off, I replaced the DEF injector today and all the errors are gone, so hopefully that’s all sorted Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #715357 1st Apr 2025 5:24pm
