![]() | Home > Technical (L322) > How to read a wiring diagram |
98_Martin Member Since: 27 Mar 2025 Location: Scotland Posts: 31 ![]() ![]() ![]() |
From my experience and knowledge I'd say you're spot on. For your 4th point BY is black with a yellow tracer. The first pages of a wiring diagram often have a colour key and some help with the other points you have mentioned. For your 5th point I'm pretty positive that is just where two wires are spliced into one for example if the pins on a connector cannot carry the required current there might be two pins used instead which then splice into one. |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 291 ![]() ![]() |
Yes, I was looking for a legend/glossary but I can't/couldn't find one.
Here's one I found on a L322 wiring diagram for my 5.0, JLR are pretty standard for these things so it should be the same
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 612 ![]() ![]() ![]() |
The 2006 wiring diagram in the wiki has a chapter on how to read the diagrams, it should cover everything needed.
Excellent, thanks. I managed to miss it. Oops. 2012 Vogue TDV8 in Aintree green over sand |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2743 ![]() ![]() |
SJ stands for solder joint, so solder joint number 905. L405 D350 SE Carpathian Grey D5 19" rims |
Thanks Graeme.
