Home > Technical (L405) > Gap tool code. Looking for advice please
Wkr
United Kingdom 2014 Range Rover Vogue SE SDV8 Scotia Grey
DSM-Driver Seat
U3001-46 (2F) Control module improper shutdown - System internal failure - calibration/parameter memory failure
( on 20-03-2025 14:21:11 at 81192 miles)
2014 L405 sdv8 vogue se
Post #715201 30th Mar 2025 4:21pm
If you clear it, does it come back...?? Pete
Post #715202 30th Mar 2025 4:46pm
Wkr
Aye sadly Pete it comes back. There’s no message or warning lights on the dash, only on the gap reader.
Post #715207 30th Mar 2025 6:23pm
fisha
Under what category is the error being reported ? ( like engine, body, suspension, etc etc ) V8 or else ...
Post #715208 30th Mar 2025 7:16pm
Wkr
What category
Sorry new to this and trying hard to give info required. DSM -Drivers seat whatever category that comes under. Will look at the manual again tonight and work things out. Appreciate all help given.
Post #715212 30th Mar 2025 7:40pm
hmallett
United Kingdom 2013 Range Rover Autobiography SDV8 Firenze Red
Workshop manual says, "Using the manufacturer approved diagnostic system, perform routine - Calibration Run (0x205F). Clear the DTCs and retest. If the fault persists, install a new driver/passenger seat control module as necessary".
I suspect that can only be done with SDD.
Post #715233 31st Mar 2025 12:47am
zenman63
England 2018 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
Having similar, changed the module under the seat, 2018 car but cannot get into it with what we had.
What exactly do I need to set up this DSM ?
Post #720474 28th Jun 2025 9:15am
