Home > Maintenance & Mods (L405) > Anyone - Cleaning out the drain plugs
Page 2 of 3 <123>
MrWold
England 2014 Range Rover Autobiography SDV8 Barolo Black
I used a bike brake cable, just the inner, to push down the tubes on a previous car. Chris
2014 FFRR 4.4 SDV8 Autobiography Barolo Black
2012 RRS SDV6 HSE Baltic Blue
and before I saw the light:
2011 Suzuki Grand Vitara SZ5
1998 Ford Mondeo V6 Ghia X
1990 Citroen BX GTi
1973 Triumph GT6
Post #655201 30th Jan 2023 11:19pm
Strimmer wire/cable works well when ive used it... Thumbs Up
Post #655207 31st Jan 2023 1:03am
Salsbury
Canada 2014 Range Rover 5.0 SC V8 Barolo Black
WaterloggedFFRR wrote:
Get it sorted out, or you could lose your vehicle. Rust can get so bad that there is no way of repairing the drain or hose. The entire sunroof assembly frame would have to be replaced. This exact problem/damage totaled my 2014 ATB. Bad design flaw. The tip that the hose connects to will rust away to nothing inside the hose and continue working until it breaks off entirely.
Was this the 405 that was shipped sea freight numerous times?
Post #655445 2nd Feb 2023 7:33pm
ABAB
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Just looking to check my drains by way of preventative maintenance (hopefully).
Struggling to find the upper drain holes however. The parts diagram posted a while back by Stan was helpful in showing rough location in the region above the B pillar.
With the sunroof fully open, are the drains still under a section of the glass roof?
I can see what look like drain holes however they are within an inner channel. I’m guessing they can’t be there however as that channel is dry, unlike a damp outer channel.
Does anyone have a photo of the drain location from above please?
Cheers. 2016 SDV8 AB
Post #678265 19th Nov 2023 10:58am
caymanblack
I would like to know too as I cannot see them either, are they visible when the roof is fully open? Thumbs Up overfinch modified
Post #678267 19th Nov 2023 11:21am
gino will tell you,
Post #678269 19th Nov 2023 11:46am
caymanblack
Bloody hell I only want to see where the drain holes are not strip my RR back to its shell. Laughing
Seriously can you get to them from the top with the roof open to check? overfinch modified
Post #678277 19th Nov 2023 1:59pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Yes you can, open the sunroof fully stand on centre console and look down into channel between sunroof and body about 1inch behind line of sunroof when opened, you can pop the trim off and its very visible, you might need a torch depending on light. I wonder actually if you could seal them up and let gravity do the rest when you drive off?
Regards fixed pano roof, i reckon you need to pull the trim and check as i bet you too have drain points, easy 2min check just pop off trim on roof, it pops back in place
Post #688079 14th Mar 2024 2:42pm
ABAB
I’ve really struggled to find and test the sunroof drain holes - couldn’t see any photos anywhere online which helped. Plenty of video and photo stuff of rusted away pipes further in the car.
So, I had a go investigating. The easiest way I found was to remove the black trim which runs the full length of the sunroof. It’s pretty easy to pop off with a trim removal tool or something similar non-metallic. The drain hole is quite a bit further back from a fully open sunroof than just one inch, so I don’t really see how the drains can be accessed without removing the trim.
I’ve attached a photo from above the car showing the location of the RH drain.
The next bit for me was 50% good. One of the drains was clear but the other not. I tried a bit of rodding with a “sunroof drain cleaning tool” but it would not go down the tube any further than about 18”. Just thinking about my next steps, but had a chat with my Indy and he suggested sorting from inside the car - at least that way I’ll be able to see if there’s a rust problem - current or potential.
What this exercise did show me is that it’s a pretty straightforward job to pop the roof trims on each side and clear / make sure the drains are clear as a regular DIY maintenance job.
Hope this helps.
 2016 SDV8 AB
Post #693234 24th May 2024 9:09am
darren3005
United Kingdom 2015 Range Rover Vogue TDV6 Santorini Black
Holey Moley I soo wanted a sliding pano roof when I went looking for my RR. I was a little disapoointed when I went with a fixed one on a vogue but as Gremlin says there's already way to much to worry about without two tiny holes ruining your day Big Cry
Post #693239 24th May 2024 10:05am
Kot
To be honest the fixed roof is the best option, I never use the sliding roof anyway. 2018 SE SDV8 4.4 Byron Blue
Post #693246 24th May 2024 12:46pm
Gremlin500
I’ve not purchased one of these as I don’t have a sunroof, but at the price it seems worth checking out?
I just found this on AliExpress: £1.49 | Car Drain Dredge Cleaning Scrub Brush for Land Rover Range Discovery Sport Guardian 4 Freelander 2
https://a.aliexpress.com/_EHlSAOU V6 Vogue - “Less is More” - less to go wrong!
Post #707909 31st Dec 2024 9:44am
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
Hello, I tried this today. Where are and how many clips on tbe black trim strip? I didn't get it to start to unclip. In the workshop manual I also couldn't find this trim strip. SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #715216 30th Mar 2025 8:26pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
You are right, it is hard to access the draining holes. I have one of those drainage tools bought from China, but made of nylon, and it was very dangerous to use (before knowing about the trim trick), the angle that is forced by the sunroof upon the tool almost made the brush dislodge from the nylon wire! I will remove the brush completely (the end is rather pointy) and try just with the nylon part of the drainage tool. For now, pouring water shows that the drains work on both sides...
Post #715241 31st Mar 2025 8:08am
Kot
Yes need to do mine Rolling with laughter watching with interest Thumbs Up 2018 SE SDV8 4.4 Byron Blue
Post #715255 31st Mar 2025 11:30am
Page 2 of 3 <123>
