![]() | Home > In Car Electronics (L322) > HK logic 7... to HD ? |
| th3chainrule Member Since: 24 Sep 2022 Location: East Posts: 19
I'm looking to swap out my HD amplifier for and aftermarket 8 channel MOST amp from Mobridge and have a few of questions:
| Krwkrw47 Member Since: 31 Mar 2025 Location: San Diego Posts: 1
Hello everyone, I am new to this forum and I read the post regarding the upgrade from the 720w system to the 1200 watt which is the one I have. However, I can't find if anyone has hooked up a custom amp to the existing 1200w premium stereo by tapping into the speaker wire and then adding the amp and custom subwoofer. Has anyone tried this and does it work? I recently did this like I have done all these previous years with all my other whips but when I did this one, it worked but the bass is 10 percent of what it could be. Not sure if the amp I am using just isn't pushing out the rated power and that being the source of my problems or is the logic 7 somehow interfering with my additional attempt to Add more bass and limiting somehow the amp output. It sounds impossible for the latter to be but you never know. Just wanted to get anyone's input on this issue before I go buy a better amp. |
| Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 351
They should be fairly obvious as they'll be pretty hefty. The input to the amp is digital/toslink/optical, so should be obvious which is which!
Not sure it will, as you'll only have one optical input which will go to either the Mobridge or the HK DSP/Amp, you won't be able to get audio into both. Your better bet would be to just use the Mobridge with passive crossovers (as per the standard HK, IIRC) then drive a separate bass-amp from speaker-level outputs to the rear channel. I would really not want to run an 8-channel amp in this vehicle tbh, I'd want at least 10. You're not going to have time alignment ability for the various speakers with just 8 and it may end up sounding a bit rubbish. There's at least 4 pairs of speakers I'd want timed differently, due to their position in the car; Rear pillars Sub back seats front seats / dash area. Ideally, I'd want to time align the tweeters on the sail panels differently than the ones in the bottom of the door. Ideally, I'd also want to be using a separate channel for the centre dash and subwoofer, so I'd be at around 10 channels minimum. Your other option is potentially to just bin off the mobridge and take some speaker level outputs from the existing amp, run that into a DSP and new amp and just go from there. You could then use a 8 or 10 channel amp+dsp combo which would be cheaper than the mobridge, at the expense of it being much less clean an install. |
Which speakers wire did you tap into? The HK amp's are an amp+dsp combination, so there is active crossover done in the DSP for certain channels. If, for example, you've tapped into anything but the sub's speaker wire, then you won't be getting the full range of bass frequencies to be able to drive a subwoofer off it. You will need to tap into the sub's feed to do that and even then, it could be there's a high-pass filter set at 40hz and a low-pass at 80 or so (guess), so you still may not be able to drive the full range of your aftermarket sub. I've no idea and I've never seen anyone publish the frequencies the HK DSP is doing crossover at, but it would logically be to the range of the speakers used, which may not be that great. I have posted a REW graph somewhere which shows the frequency response of the default HK system, which may be helpful if you search my posts.[/img] |
| bd5400 Member Since: 17 May 2025 Location: WI Posts: 7
For those who have done the upgrade, how did you handle the different connectors between the non-HD speakers and the HD speakers?
You can just cut with pliers and solder if you’re not bothered about retaining the plugs.
I ended up figuring out the connector type (11717), bought several, and have been splicing in the connector in order to use the new speakers. So far, it has worked wonderfully, though the project is paused because of an unrelated issue that has come up in the meantime.
Yup, that’s the thing, there are more speakers than there are channels on the amp/DSP, so some are using passive crossovers with multiple drivers on a single channel.
