Home > Technical (L322) > Vibration when stopped in gear.
FIREBIRDL322
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi Everyone,
I have had this strange vibration in my car since September. It all started when I had my CV axles replaced from a specialist. After getting the car back there was a big vibration from the car that could be felt in the passenger seat, steering wheel and at times would vibrate the wiring inside the A pillars ever so slightly. The vibration would only happen when the car is stationary, in drive or reverse, and when the steering is turned either to the right or left. It doesnt matter how far the wheel is turned. It goes away when the car is in neutral. When driving there is no vibration, gearbox feels fine, however, after doing a few motorway miles 60mph+ when stopped in traffic the vibration is back even without turning the steering wheel. I have had the shop look at it twice and they say there is nothin wrong with the car and it will go away after a while since the CV axles are new. The vibration is still there till this day. I had taken it to a local garage and they told me to get the engine mounts replaced which I did (genuine parts). However, after replacing the vibration is still there albeit, the vibration is not as bad as before. Has anyone had this happen before, or does anyone have an idea on where else I can look? any ideas would be of great help Bow down
Thanks, Nigel 2014 Range Rover Autobiography 5.0 Supercharged V8 L405 (STOLEN)
2012 Range Rover Sport Autobiography 5.0 Supercharged V8 L320
2012 Range Rover Sport Autobiography 3.0SDV6 L320 (SOLD)
2011 Range Rover Autobiography 5.0 Supercharched V8 L322
2010 Range Rover Sport 3.6 TDV8 L320 (SOLD)
Post #715270 31st Mar 2025 1:47pm
FIREBIRDL322
Any solutions or clues on where to look would be greatly appreciated. I've plugged in my gap iid and found nothing. 2014 Range Rover Autobiography 5.0 Supercharged V8 L405 (STOLEN)
Post #716405 19th Apr 2025 3:45pm
i cant help but try a forum search.. Thumbs Up ... - .- -.
Post #716406 19th Apr 2025 4:10pm
Sp00c
United Kingdom 2011 Range Rover Autobiography TDV8 Stornoway Grey
I had the exact same issue!
The garage said it wasn’t the drive shafts they replaced. It actually ended up being the rear prop shaft, the centre bearing was knackered and they replaced the whole rear shaft. Solved the vibrating when stationary, my only issue now is since this there is a thumping sound from the rear of the car when hard acceleration from stationary.
( I have recently put a post on this section regarding it).
Hope this helps
Post #717235 1st May 2025 4:34pm
FIREBIRDL322
Thank you very much for the suggestion. I'll have a look with my garage to get the center bearing replaced. Took the car yesterday to the same specialist and was told there is nothing wrong maybe a power steering fluid change would help. I think the center bearing is a more likely cause. I will report back once the part is replaced. 2014 Range Rover Autobiography 5.0 Supercharged V8 L405 (STOLEN)
Post #717281 2nd May 2025 4:20pm
