![]() | Home > Maintenance & Mods (L405) > Faulty thermostat? |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1558 ![]() ![]() |
Whilst I dont have a 5.0SC, my experience of all the V8's i've had before ( 3.5, 3.9, 4.0, 4.2SC, 4.4) is that they have all had no issue with getting up to temperature ... as engines in general, petrol V8's just dont run cool by themselves. As far as a I know, the thermostat should regulate at 95degC at factory spec and that some have fitted an 85degC replacement. So if you're not getting upto operating temp, then its being over-cooled, which really can only come from the radiator doing the cooling ... which is fed by the thermostat.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3278 ![]() ![]() ![]() |
as fish said, most probably thermostat. On my Diesel TDV8, my thermostat housing was cracked by a garage doing an inlet manifold replacement, causing the engine to run cool. |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 256 ![]() ![]() ![]() |
Temp sensor 1 is located at the rear of the engine. Temp sensor 2 is located at the thermostat stat.
Looks like the aftermarket thermostat failed. New OEM unit on order as a warranty repair. I will update once the shop replaces it. Dan. 🇨🇦 2013 L405 5.0 SCV8 |
OEM thermostat swapped in by the shop today. Instantly better. I saw temps as high as 97/75. I will idle in place for a bit to heat soak the engine until the fan comes on and see what happens.
