Home > Technical (L405) > Radar Sensor Blocked fix
f4rrs
United Kingdom 2016 Range Rover Vogue SE SDV8 Loire Blue
Hi there, My new to me L405 has a radar sensor blocked error message. I understand from research that the sensor is behind the front bumper. Has anyone else had a similar issue and could cleaning the sensor fix it or does it need a new sensor. Any help/experience on this would be greatly appreciated.
Post #715481 3rd Apr 2025 1:15pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
How dirty is the bumper? Normally comes up in snow conditions or if something's blocking it, seems a bit strange, I would be more concerned you have a red triangle up!
I am sure someone will be along soon with some words of wisdom...
Post #715489 3rd Apr 2025 5:17pm
adrianmoore2005@gmail.com
United States 2014 Range Rover Autobiography 5.0 SC V8 Indus Silver
Did you fix this?
Post #721061 9th Jul 2025 11:16am
GraemeS
Australia
The one on my previous L322 failed with the same message. I eventually disabled ACC in the CCF to regain the use of standard CC as the cost of a new one was prohibitive. L405 D350 SE Carpathian Grey D5 19" rims
Post #721063 9th Jul 2025 11:52am
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
I have the same issue with mine, although it works a lot of the time but fails at the exact same spot in 4 different locations.
Not related to journey time - but always pings up with big yellow triangle... it actually does come back to life a short whiel later but again fails at the next place. I'm wondering if there are radar devices in those places that screws mine up..?
Anyway, at £399 for a used one on eBay I doubt I will bother to fix it.
Graeme, I guess we can live with the IEBA system as well and go back to good old CC..!! Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #721065 9th Jul 2025 12:06pm
Kot
@comports
It happened to me on 1 occasion on a motorway, maybe it was a F35 lighting me up Shocked or just local plod with his death ray? Whistle
I was soon able to reinstate it.
But if its a permanent fault thats a different matter of course. 2018 SE SDV8 4.4 Byron Blue
Post #721068 9th Jul 2025 1:15pm
f4rrs
No, not fixed. Thinking of removing the front bumper and cleaning the sensor but haven't got round to doing it as yet.
Post #721073 9th Jul 2025 3:22pm
fisha
How much have you driven it ? I’ve found that sometimes if the vehicle has been reset or out of charge and the systems need to start from scratch then things like the radar need time to learn /reset themselves. Ie it kind of self calibrates whilst on the move V8 or else ...
Post #721086 9th Jul 2025 6:08pm
Mine has errored twice, both times in the motorway with torrential rain.
The GAP tool said something along the lines of “sensor blocked”.
It seemed to sort itself out after some time and the rain slackened off. Got - 2017 SDV8 Autobiography in Loire Blue
Post #721087 9th Jul 2025 6:33pm
GraemeS
Australia
If the L405's mounting is like the L322's then it's basically impossible for any material to get between the radar unit and the bumper because the front of the unit fits into a recess in the bumper. L405 D350 SE Carpathian Grey D5 19" rims
Post #721099 9th Jul 2025 9:35pm
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
if you get blocked sensor message and bumper is clean then 90% sure is wrong mounted. i.e. someone hit bumper and bent s3nsor bracket. It is really soft to protect sensor from damage. you need to bend it back straight as much as possible with hammer, set with bubble eye and wire to look straight forward, then do the calibration wit IID. ACC should again work as it should.
Post #721104 9th Jul 2025 10:10pm
