Home > Maintenance & Mods (L322) > Stripped Thread on Brembo Front Calliper
Pat
Scotland 2013 Range Rover Autobiography SDV8 Causeway Grey
Looking for advice whilst trying to bleed front brakes after some work I have stripped threads on Front Brembo caliper any suggestions on how to fix this
Thanks
Post #715542 4th Apr 2025 2:55pm
Mikey
Bleed nipple threads or carrier bolts?
Post #715546 4th Apr 2025 3:32pm
Pat
Bleed nipple thread
Post #715548 4th Apr 2025 3:40pm
Mikey
OK, so. Bear with me Laughing
Nipple Therapy
It's an actual repair kit, with a drill bit, appropriate sized tap and new bleed nipples to drill out and reseal Thumbs Up
Post #715551 4th Apr 2025 4:28pm
Gremlin500
@Mikey:
Not seen this before, care to post your source? Bow down
@Pat:
To stop this happening again and next time trashing your calipers:
Take each new bleed nipple, and very carefully wrap each with 3 to 4 turns of PTFE tape, being very careful not to let any stray tape get anywhere near the inner part of the nipple (where the brake fluid is)
This will provide a dielectric barrier between the two dissimilar metals, and prevent the galvanic corrosion from welding the steel nipples to the aluminium caliper body.
I have done this for years, and it just works. Thumbs Up V6 Vogue - “Less is More” - less to go wrong!
Post #715568 5th Apr 2025 12:25am
Happydaze
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Brake nipple repair search on eBay gives a variety of results including the therapy thing pictured, at 85 quid! Nielsen do a similar looking kit for 24 quid and big red (good supplier) do a kit with helicoils and all the tooling for 15 quid.
Chris
Post #715607 5th Apr 2025 4:14pm
PDC
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
Iv'e just replaced all my bleed nipples for titanium ones to stop this happening. To get my steel nipples out I applied heat to the calliper around the nipple from my heat gun & they loosened a treat. 2010 RR Autobiography 5.0 SC
2020 F-Pace SVR 5.0 SC
2018 RRS HSE Dynamic 3.0
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #715670 6th Apr 2025 5:47pm
Steveg
United Kingdom 2011 Range Rover Autobiography TDV8 Orkney Grey
Or just use aluminium high temp anti seize on the threads. Can also be used on back of pads, hub to alloy interface, injector threads, glow plug threads, anywhere there’s an aluminum to steel connection or height temp use like exhaust nuts.
https://eshop.wurth.co.uk/Product-categori...Twqhag64Um
Any decent brand will do.
Gremlin500 wrote:
@Mikey:
@Pat:
Post #715690 7th Apr 2025 8:39am
