Home > Technical (L322) > Blue smoke on acceleration after changing oil cooler seals?
3mile3llis
United Kingdom 2009 Range Rover Vogue SE TDV8 Bournville
Hi all,
New l322 owner here, and new to the forum!
Recently bought a 3.6 tdv8 and have had a fair few repairs to do so far.
When I picked it up it drove spot on and there was no smoke, however there was plenty of oil leaks.
I traced one of the leaks to be the oil cooler, so I set upon fixing it. Stripped it all down and took the complete housing off, took the oil cooler, oil filter housing and oil separator off, cleaned, replaced seals and re assembled with a new oil filter also. I also took the opportunity to blank the egr’s and clean out the manifold that houses the throttle bodies as it was very mucky.
Once reassembled it seemed to run fine and no oil down the bell housing, went on a test drive and no issues.
The next time I drove it after it been sat for a while I was getting massive clouds of blue smoke on hard acceleration for about the first 10 minutes of driving and then it clears.
There seems to be a pattern with the longer it sits between using it the worse the smoke is to begin with.
I am now in the middle of changing the inlet manifolds due to more leaks, and when I took the manifold off with the throttle bodies the inside was already very oily after I had cleaned it previously.
Its also worth mentioning it had new turbos about 40k miles ago.
Does anyone have any ideas as to what might be causing the smoke and the oil in the inlets? It was fine before I took apart the oil cooler. Very strange.
Thanks in advance!
Post #714800 24th Mar 2025 8:17pm
ChurchMuch
Kenya 2007 Range Rover Vogue SE TDV8 Java Black
This sounds like a leaky injector.
Get live reading of the injectors and you should be able to see the culprit.
Post #715696 7th Apr 2025 10:50am
ashtrucker
Check the leaf spring which sits under the oil filter make sure it’s seated properly think it’s the same oil cooler as on the 4.4 2012 Westminster 4.4 tdv8
Post #715702 7th Apr 2025 12:08pm
3mile3llis
Funnily enough I am currently working on replacing the seals on the inlet manifolds due to oil leaks and it looked like there was leaks from around there.
Hopefully when I finish the job it might cure the other issues.
Post #715712 7th Apr 2025 2:29pm
3mile3llis
So I have heard about this before but can’t find anything underneath my oil filter housing. Is it missing completely or is the 3.6 different to the 4.4?
Post #715713 7th Apr 2025 2:30pm
ashtrucker
Looks different from the 4.4 on the actual filter element dose it have anything sticking out from the bottom to plug the drain hole 2012 Westminster 4.4 tdv8
Post #715716 7th Apr 2025 3:08pm
ashtrucker
To answer my own question yes the filter for the 3.6 dose have a protrusion on the bottom of the filter to plug the drain hole. Sorry for wasting your time hope you get it sorted 2012 Westminster 4.4 tdv8
Post #715717 7th Apr 2025 3:11pm
