![]() | Home > Technical (L322) > Today's problem, central locking |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1393 ![]() ![]() |
Today I clipped my phone to the vent on the dashboard, in doing so I locked/unlocked the car from the button on the dash quite a few times fitting the phone holder, anyways gets to my destination and low and behold central locking from the fob has stopped working, central locking still works from manually using the key in the door, alarm still sounds on locking and unlocking.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7964 ![]() ![]() ![]() |
Could be wrong, but doesn’t it ignore the fob if the car is locked and unlocked so many times in quick succession? For a length of time? Thought I’d read it somewhere. Like if it’s being pressed accidentally in your pocket…. I know it’s the switch you pressed but could be similar….
Sometimes I surprise even myself 🤣 knew I’d read something…
Cheers, that's something to look at, do you have a link to the text you uploaded?
It’s from the Workshop Manual, downloadable from the Wiki, top right under the fullfatrr banner.
It’s the 2011 workshop manual, but I’m sure earlier cars were the same. 2011 Range Rover Vogue SE 4.4 TDV8
Well it's decided to fix itself, all working as normal this morning, maybe it just needed a good nights kip 🤔 |
That will have been the repetitive blocking then.
