Home > Maintenance & Mods (L322) > Refurbed door plastics
Page 1 of 3 123>
AndrewT
New Zealand 2003 Range Rover Vogue 4.4 V8 Oslo Blue
The plastics around the switches and handle in my front door were really badly damaged (presumably by the previous owner's jewellery) and needed sorting out. The rubbery finish on the switch surround was peeling in places which exposed some nasty shiny plastic underneath and the foundry paint had large chunks missing.
I forgot to take a pic of the switch panel but here you can see the state of the handle trim sat on my state-of-the-art painting stand.
I wanted to do the handle trim in Foundry but couldn't get a decent enough match and so opted for Halfwits satin black instead. If I ever find the right code for Foundry I can always redo them. A good rub down to remove all the old finish is really important as the old paint will react with the new paint and bubble up otherwise. 2 coats of primer and 2 colour coats later and the end result looks much better.
What do you think? Leave it like this or redo in Foundry at some point? I quite like it as it contrasts well with the rest of the interior. The switch panel doesn't look as shiny in real life as it does in this pic.
With one handle done the passenger side looked daft still in silver so that got done too. I didn't do the switch panel on this one as I couldn't be arsed to take the door trim off.
Total cost about £2. That's the kind of upgrade I like! :D
Post #71560 7th Jul 2011 4:57pm
f4rrs
United Kingdom 2016 Range Rover Vogue SE SDV8 Loire Blue
NICE JOB Very Happy
Post #71564 7th Jul 2011 5:23pm
very nice work..leave it as it is as the range looks ok with a few different colours.
this is mine and all the colours work well..
Post #71565 7th Jul 2011 5:52pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Nice job, FYI Supercharged RR's had piano black door handle surrounds rather than foundry finish, so my vote is to keep it black Thumbs Up
Gone - Range Rover Supercharged 2006
Post #71576 7th Jul 2011 6:19pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
I have a similar problem with badly scratched panels and was thinking of spraying them. How easy was it to sand the rubbery finish on the switch panels, can it be painted over or did you have to get it all off? No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #71578 7th Jul 2011 6:25pm
AndrewT
Thanks for the positive reviews. Thumbs Up
The rubber finish needs to be completely removed. I tried putting the primer over it but it just bubbled and lifted. Some bits came off very easily but others were a bit trickier. Spraying the primer on by mistake actually made it easier to remove as more of the rubber lifted but it was a bit messier and no quicker than just sanding it all off at the beginning would have been.
A good rub with 240 grit followed by 800 to get the deeper scratches out then it was ready for the primer. The handle trims took the same amount of effort. It was no more than 15 minutes sanding per item so fairly easy.
Post #71580 7th Jul 2011 6:34pm
pretlove
i painted all mine gloss black and as said earlier so long as you give them a good sand down and use a etching primer they do come out well ....on mine i did lots of coats then when it dried i wet and dried it so that i could get a nice gloss finish.........with regards to the window switch surrounds mine are pealing to so im just gonna take all the rubber coating off and have them just black plastic Thumbs Up
good job by the way looks much better in black than foundary
if you use car polish on the rubber it comes of easy as it seems to break it up ... this is what i did with the steering wheel spokes "RANGEISM WILL NOT BE TOLERATED"
Post #71595 7th Jul 2011 7:03pm
AndrewT
Not sure whether the plastics stayed the same over the years but the switch surround plastic looks really cheap and nasty under the rubber. It's got a shiny but textured finish and wouldn't look out of place in an 80's Vauxhall. Have a look but you might want to prime and flatten before using the same paint as your handle trims to get a finish that's as good as what you've already done.
Nice tip for the steering wheel spokes as I was wondering how I was going to tackle them without taking the whole thing apart. Thumbs Up
Post #71601 7th Jul 2011 7:26pm
pretlove
andrew i fear you may be right about the switch surrounds so maybe once ive got the rubber off ill just paint them like the rest Thumbs Up with regards to the polish trick i found the cheaper the polish the better it worked....dont get me wrong it still takes a bit off elbow grease and does take some time to start working but it does work "RANGEISM WILL NOT BE TOLERATED"
Post #71613 7th Jul 2011 7:56pm
grant
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Really looks great Andrew - I prefer that to the Foundry finish. I'll pop in to Halfords on the way home; busy weekend ahead. Tow bar electrics and now spraying.
Post #71699 8th Jul 2011 1:45pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
can we see some pics of your gloss black parts i want to change mine to gloss black
Post #71812 9th Jul 2011 7:14pm
pretlove
there on my range rover thread Thumbs Up
i will take some fresh ones for you right now "RANGEISM WILL NOT BE TOLERATED"
Post #71822 9th Jul 2011 8:14pm
pretlove
please excuss the dirty inside it needs a clean Embarassed "RANGEISM WILL NOT BE TOLERATED"
Post #71825 9th Jul 2011 8:20pm
mattstevenson2005
thanks for that!
Post #71844 9th Jul 2011 10:09pm
Mikeyjd
Very nice. Same colour as mine. I need to have a go at that when I get some free time. So much to do and so little time No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Post #71847 9th Jul 2011 10:32pm
Page 1 of 3 123>
