![]() | Home > Wheels & Tyres > L405 285/45R22 Pirelli Scorpion Verde |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 256 ![]() ![]() ![]() |
There are many threads on this and here is mine.
Thinking of trying these on wifeys 405… |
Why would you change the spare to that size sir? That’s not the same size as the 285/45/22? Or did you think it was? |
Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 200 ![]() ![]() ![]() |
That is the spare tyre size on the L460 that is supplied with 285/45R22 tyres.
I have a full size spare and was curious if the 285/45R22 would fit in there. I may look for a single tire and swap out the spare.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35868 ![]() ![]() |
there are a few nice sets [L460/L461] on ebay and i'm very tempted especially for the more comfortable ride... ... - .- -.
Do it! 🙂
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3818 ![]() ![]() |
Just something to bear in mind - raising the aspect ratio, increases the rolling radius, which increases the gearing, and DOES dull acceleration. I have learned this from experience, nothing to worry about, but something to consider as the impact is greater the lower the BHP of the engine…. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
yes indeed, and the speedo will be out as well..
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1877 ![]() ![]() ![]() |
@Stan:
The speedo now reads the same as the GPS so there is now zero difference in indicated/actual speed. I think the factory speedos are all calibrated on the low side and I understand that is usual to do so.
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 507 ![]() ![]() ![]() |
This year, I need to replace all four summer tyres so I can consider changing. But living in Germany, I will need to get a TUV exception to fit them. So before I look at that paperwork.
kungfupanda Member Since: 24 Jun 2013 Location: Manchester Posts: 235 ![]() ![]() ![]() |
There’s a decent priced set of four new 285/45/22 Michelin all seasons on EBay…
Thought I would add a couple of pictures of towing with 285/45R22. Pressures set to 44/50 psi. Handles like a dream. I barely felt the trailers behind me.
