| Start and die with 2 new MAFs? | |
Hey guys, let me know if anyone has dealt with this? I've got an 07' L322 4.4L and have been getting a lean condition fault. It runs fine but you can smell that it is indeed lean. I decided to replace the MAF. I've had this truck for over a decade and it's got 244k miles on it so I'm sure I've replaced the MAF previously but can remember 100%. Back in the day I would always get the cheapest Amazon parts I could find but have learned the errors of my ways over the years. That said I ordered a $175 Delphi unit from FCP Euro but when I put it in, the vehicle would start and immediately die as if you had the intake boot off of the throttle body. I ended up returning it as I was thinking that it (while unlikely) was a defective part. I accidentally choose refund instead of exchange so I needed to order another one. I had to order a ton of stuff from Atlantic British so I added one to my order. On both sites, I put in my specific vehicle info and it she the appropriate part which was the Delphi unit again. I received the MAF today, installed it, and it did the exact same thing where it starts and dies.
I saw someone mention that you would need to clear the engine adaptations. I just put it back together after replacing the throttle body and plenum gaskets and cleaned the **** out of the throttle body and intake so I actually cleared the engine adaptations last night before starting it (with the existing MAF and haven't driven it.
The MAF that's been in it is a Denso unit but didn't think it should make a difference. I'm thinking I should try to find another Denso instead of the Delphi as I can't think of anything else.
Any help is appreciated!
