![]() | Home > Maintenance & Mods (L405) > Oil level gauge Dipstick p400e |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 884 ![]() ![]() ![]() |
That’s very interesting! At every oil change, I noticed that the level was way beyond the maximum limit—including the out of warranty oil change, where I personally added the exact amount of oil required. Right now, the car is unfortunately at the dealer, so I cannot verify the size of the dipstick or the number. However, as soon as I get it back, I will check and update you.
Actually, I found out that this was discussed as early as 2021 and I forgot about it!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35861 ![]() ![]() |
is this dipstick specific to the p400e....
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2765 ![]() ![]() |
The D350 L405 has a dipstick. L405 D350 SE Carpathian Grey D5 19" rims |
Rio Member Since: 03 Jun 2024 Location: Albi Posts: 24 ![]() ![]() |
Thank you for your answers.
All right, car back, so I checked, and the dipstick is exactly the same number as yours and also the same length, 78. Luckily, the oil level in mine is about 1 cm above the max level, as recommended in the bulletin. I'll have to keep that in mind for the next changes...
Great thank you very much 👍, so I will add the 0.5l that I drained, the dealer was right, they put the right amount 7.02 l
captfish2003 Member Since: 17 Apr 2025 Location: Scotland Posts: 18 ![]() ![]() ![]() |
How can you guys read the oil level? When I pull the dip stick out the oil is smeared well above the max level. Even after cleaning and reinsertion it’s still too messy to read.
Looks like this when pulled out. Also the dipstick has the model number 54959G.
It shouldn't be like that. Did you measure after 15 minutes with engine off?
I measured it this morning with a cold engine. Also seems to make no difference whether I clean it. It comes out full of oil. I will measure it. |
Spot on 78cm. Wonder if the stupid cork screw design brings up the oil in the dip shaft. Impossible to get a reading - or it might be overfilled by 10cm or so. |
Try to push it several times (5- 10) without pushing it all the way (you let it come out 10cm)
Thanks - good advice. Haven’t thought about that. Will try it later. |
