Home > Maintenance & Mods (L322) > gap iid tool,,,dpf full again
miketrike
United Kingdom 2011 Range Rover SE TDV8 Baltic Blue
i was reading a post that said my dpf full message may be faulty exhaust sensor ..if i use my iid tool to measure how much soot is in dpf will this be a true measure or is this a faulty measure due to faulty sensor...i changed my oil cooler about 100 miles ago and cleaned throttle body and four holed box behind as best i could ,this lead to dpf full and so i took down motorway for thirty miles which cleared the dpf soot and any smoke that i had at first...this morning i went collect fresh bread only three mile round trip ...no yellow dpf light just went directly to red ..dpf full visit dealer..any body got any idea ..im off for another thirty miles of wasted diesel ,,its getting boring now! 2011 tdv8 4,4 70k miles id like to thank you guys for for help in the past few months ..also changed my air con condensing rad ..start to finish 5 hrs ..ice cold now ..mike
Post #716385 19th Apr 2025 8:27am
PeteT80
Check for any air leaks around the 4 hoses onto the doughnut, and the intake hose onto the throttle body. Maybe do a smoke test to be sure.
Post #716393 19th Apr 2025 10:19am
Dtech
England 2011 Range Rover Vogue 4.4 V8 Santorini Black
Sounds like the exact symptoms I had, which was caused by split left hand intake manifold. But as mentioned above I would be checking all intake hoses as your first option, which would be a much cheaper fix.
Post #716399 19th Apr 2025 12:23pm
miketrike
intake mani fold
im hoping its not that..i only did oil cooler last week and could nt see any problems ..i wondered if there was a way to test you may know ..i dont mind fixing em its the diagnosis that so long winded thanks for reply im getting smoke test...i did think throttle body intake was a little loose held in b y shaped clip ill have another go at it ..id have thought gap iid would have shown air leak.. anyway ive been down m5 and its all back to 2 per cent soot..thanks for reply Mike
Post #716404 19th Apr 2025 2:06pm
