![]() | Home > Technical (L405) > SDV8 Service interval - confused |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1553 ![]() ![]() |
It can drop quickly the service distance. Particularly if its wanting to try and do a regen. Each time it tries to do a regen, it will drop the service distance a set amount ( lets argue 1k miles ).
RichTDV8 Member Since: 16 May 2010 Location: Berkshire Posts: 57 ![]() ![]() ![]() |
Fisha thank you
On the IIDtool, the soot value seems to try and regen itself down to a value around 6 or 7. It'll then build up to around the 20 mark then want to regen. At about 23-24, it shows a yellow warning on the dash, and I dont know what a red warning value is. V8 or else ... |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1433 ![]() ![]() |
Some night time reading for nerds |
^^^ I was trying to avoid pushing the poor chap off the cliff !! V8 or else ... |
hmallett Member Since: 21 Jan 2024 Location: Mid-Wales Posts: 154 ![]() ![]() ![]() |
Absolutely this. I have been tracking my DPF related stats (thanks to the paranoia induced by this forum!). As part of that I have been capturing the distance since the last oil change and the distance to the next service. Add them together and you get the (then current) distance between services. When the service indicator is reset it records 26,000 km to the next service. After one oil change the distance between services dropped to about 20,000 km, usually dropping slowly, and occasionally increasing slightly. Then, after a holiday towing a caravan about 1,000 miles, that distance plummeted to 15,000 km. In two weeks the distance since last oil change increased by 1,980 km, and the distance to next service dropped by 7,225 km. I changed the oil soon after that. After the second oil change the distance between oil changes dropped quite quickly from 26,000 km to 16,000 km. No idea why. Hope that's helpful! ![]() |
