Home > Maintenance & Mods (L405) > Wiring Cut Location for Ignition Immobiliser?
NoHandSignals
United States 2016 Range Rover 5.0 SC V8 Aruba
Looking for guidance on where the wires are, and which wires I should cut to splice this immobilizer in?
I think the diagram is pretty simple, after removing the instrument panel trim though I don't think I'm meant to literally splice into the low voltage wires behind the push-to-start switch like the diagram shows?
2016 V8 SC LHD. Any help or suggestions appreciated Smile
Post #716452 20th Apr 2025 2:38pm
Can I suggest that if anyone knows the answer then they PM the OP as IMHO this is not the kind of thing we want on an open Forum.... Whistle Pete
Post #716456 20th Apr 2025 4:05pm
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
because wiring location at topix is super-duper top secret knowledge. Known by Shaolin monks after 10 years of ascetic.
Post #716457 20th Apr 2025 4:13pm
The wiring is not the issue, the place for a splice is...... Rolling Eyes Pete
Post #716461 20th Apr 2025 4:58pm
jimmie
splice point in not critical. Doing thist to stay invisible and without marks of panels dissassemby. You can do that close to swich and will not look like someone modified something.
Post #716465 20th Apr 2025 5:56pm
NoHandSignals
Hi Jimmie,
I was worried about cutting the wires near the switch as they just look more like low voltage signal wires than anything else, and the wires that came with the immobiliser are much thicker. Maybe it’s just about breaking the circuit and it doesn’t matter?
Post #716469 20th Apr 2025 7:27pm
jimmie
this is just cutting start signal. You can easily bypass that if you know system. But... if thief will try to steal and button will not work then in most cases just leave car and look for other one.
Post #716470 20th Apr 2025 7:30pm
NoHandSignals
OK, so I’m just going to keep it simple and cut behind the push to start switch. Can anyone tell me which different wires here do what? I couldn’t find the push to start in the wiki section wiring diagrams.
Cheers 🍻
Post #716475 20th Apr 2025 9:14pm
NoHandSignals
Okay so, I found the wiring diagram for the Push-to-start switch (thank-you for a great wiki!), but still need some help. There are 2 hot wires into the switch for the Push-to-start system, not sure which one I should cut for the immobilizer or if I need cut both?
There are 5 wires total, but thanks to some older posts (thanks Fifth Horseman)I know that the blue/white and black wires are for illumination supply and earth respectively, and that the green/white is the -ve from the Push-to-Start system. Its the brown and Yellow/Orange that both seem live that I need to understand what to do with.
TIA
Post #716859 26th Apr 2025 8:34pm
jimmie
if you cut one, then in case of pressing start blocked car you will get start button circuit fail.
so... you need to cut both of them in the same time or cut ground wire
Post #716860 26th Apr 2025 8:50pm
NoHandSignals
Jimmie, thanks. I will cut the -ve then. Do you know what the two different hot wires do, and which I should splice into for the other side of circuit for this immobilizer?
Post #716864 26th Apr 2025 10:43pm
did you cut the ground/earth in the end and did this work? ... - .- -.
Post #717882 13th May 2025 3:07pm
NoHandSignals
Yes, just cut the single yellow/green Push-To-Start switch -ve wire only. Also connected the immobilization system itself to both the a permanent and accessory live in the passenger fuse box. That was all necessary.
All good. Thanks for the help, everyone.
Post #717911 14th May 2025 3:39am
Thanks Thumbs Up ... - .- -.
Post #717912 14th May 2025 6:59am
