Home > Maintenance & Mods (L322) > Seat options 2010-2012
JonnyCJ
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Sumatra Black
My Vogue SE has the perforated leather heated and cooled seats without the piping. I’m assuming these are semi analine ? They could do with tidying up and seem to wear less well than the non-perforated piped seats, but assume those don’t come with the cooling option ?
Debating on whether to swap the seats out for the piped version, but would be interested to hear from those in the know the pros and cons of the various options as my brain is a bit muddled on it.
Thanks in advance.
Jonny
Post #716514 21st Apr 2025 7:04pm
CS
Vogue SE had perforated semi-aniline leather seats, heated and cooled, whereas Vogue had Oxford leather seats, heated only. Oxford would be harder feel leather, not sure if necessarily harder wearing, but maybe the perforations required for cooling would be a negative factor as regards wear. AB had the same seats as VSE.
I'm not sure that piping was a thing in 2012, my 2011 brochure does not show piping and it's not mentioned. It was used on the P38, especially on the higher trim grades, where one could have contrasting piping. The P38 seats were Connolly leather and I regard those in my P38 4.6 Vogue as the most comfortable seats in all my RRs. Connolly went bust and later RRs have Bridge of Weir leather. Only Range Rovers since 1988
Post #716517 21st Apr 2025 7:52pm
JonnyCJ
Thanks for the comprehensive answer CS. Helps make up my mind to stick with what the car came with and spend the money getting them re-furbed. Handily there’s an ex Gliptone specialist 8 miles up the road who restores seats for a living, so will gauge his opinion and get some prices.
Post #716523 21st Apr 2025 8:23pm
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Hey Jonny, I see your OCD is still active lol. If you've got some spare time on your hands, you could always try to refurb the seats yourself. Believe it or not, it is very easy, just need patience. I did mine on my old overfinch with ivory seats which I think are the worst as cracks show more in the leather. All you need is some really good leather cleaner, leather food, correct colour leather dye and a heat gun. I think it took me a whole day to do both front seats, the end result was amazing. I think I have pictures on here somewhere before and after. A bit like yourself, I like things to be perfect and was very satisfied with myself after I did mine.
Post #716540 22nd Apr 2025 8:43am
Barmybrummie
https://www.fullfatrr.com/forum/topic6052-5235.htm
Pictures of my seat refurb
Post #716541 22nd Apr 2025 8:53am
Barmybrummie
Sorry the link doesn't work so here's the pics.
Before
After
Post #716542 22nd Apr 2025 8:56am
JonnyCJ
Thanks BB - I’ve actually had a lot of success doing something similar but on a smaller scale. It’s very satisfying. You’ve got me thinking it maybe worth doing them myself.
Would probably need to spray them to get the best finish, but that way I can do one at a time rather than have the car out of action for a few days.
Hope the recovery is going well - nearly a week in !
Post #716546 22nd Apr 2025 11:22am
Barmybrummie
To be honest Jonny I didn't spray mine, I left a wet cloth on them overnight to supple up the leather, gave them a damn good clean and then wet them again and used the heat gun to pull out all the creases, this works remarkably well. I bought some cheap fine artist brushes from eBay and used those to apply the dye thicker in the most worn places. I cheated and used the heat gun to dry the dye much quicker and repeated until it fully matched. Then after I just used the sponge to apply several coats of the dye to whole of the worn seat. I think I did about 5 coats, left it overnight and then gave it all a good treatment of leather food. It was still looking good a year after when I sold it. Took me most of the Saturday to do it and 2 hours in the Sunday morning start to finish. I used glipstone it's expensive but brilliant stuff. The only thing that annoyed me about it was the after smell, it's awful. It smells like diesel and took weeks for it to disappear, it then smelled like a 1970's rover P6.
I'm not too bad thanks matey, I'm walking around ok, had a walk to the shop, started the car which fired straight up which I'm shocked about since it hasn't moved for a week. Tiny bit of pain still around the abdomen, don't think the daily injections are helping that cause though. Do get tired quite easily though, but that's normal from what I hear after keyhole surgery. Got my daughter with me for the week, she only 15 so looking after dad. Another week of the catheter, I'm used to it now, but it's still just an inconvenience.
Post #716548 22nd Apr 2025 11:52am
JonnyCJ
As luck would have it I have some Land Rover Ivory NUG leather filler and paint lying around in the workshop. Both from Scratch Doctor. What are the odds…
I can get practising on the driver’s seat, which is the worst and if I cock it up I’ll call in the pros.
It’s a good excuse to buy a mini spray gun if nothing else.
Good to hear you’re up and about.
Post #716552 22nd Apr 2025 12:12pm
Barmybrummie
In all honesty Jonny, you won't cock it up, it really is so easy. In fact, it will be even better that you have leather filler, will save you lots more time. Little tip though, if you use the filler use the finest wet and dry you can get and lightly sand over it once it's dried. You'll get a much better flatter and smoother finish and makes using the dye even easier. Shame I'm not local, I've got nothing to do for the next 6 weeks lol.
Post #716556 22nd Apr 2025 1:32pm
JonnyCJ
Good tip - got all the way up to 5000 grit. As with everything, prep is the key, so I'll make sure the seats are as clean as poss before starting.
Probably a good job you're not local - not having you leaking your bag all over the shop Shocked Laughing
Thanks Stan for moving this General enquiry thread to the new correct home !
Post #716566 22nd Apr 2025 2:15pm
Barmybrummie
Thanks Jonny, at least it would take the glipstone smell away Laughing
The other thing about me not being local, you seem to be finding all sorts of stuff in your shed, I do like a good mooch around lol.
Post #716572 22nd Apr 2025 3:09pm
Eastsoutheast
United Kingdom 2012 Range Rover Vogue TDV8 Santorini Black
I have a 2012 L322 Vogue which has piped perforated (not outer bolsters) heated and cooled leather seats. If I understand some of the previous posts this should not be available on my car?
They are cream and extremely hard wearing so still look fresh. 2012 4.4 TDV8 Vogue Santorini black ivory leather
Post #716605 22nd Apr 2025 9:06pm
CS
Maybe these could be specified on Vogue as an extra, my 2012 WM had the heated and cooled seats, it was a run-out model which I thought probably used some of the extra items that were left over at the end of the 322 run.
While looking at this later question I found the 2003 322 brochure and some of the seats there did have piping, my recollection is that my 2004 Vogue seats were more comfortable than the 2012 WM seats, but the seats are not identical so Q if they could in fact be swapped. The 2004 car had heated but not cooled seats, I wondered at the time whether the addition of the kit for the cooling had an adverse effect on comfort.
Another point of interest (to me anyway) was from the 2004 price list: a V8 Vogue (then the top model) was £60,995 OTR, compare that with the P530... Only Range Rovers since 1988
Post #716616 22nd Apr 2025 11:14pm
Barmybrummie
My 2011 vogue has the air cooled and piped seats. Whoever ordered it new must have had a fair few other options fitted from factory. If you was to look at mine you would say it was a Vogue SE. Rear entertainment, suede roof lining and leather parcel shelf. The only thing it doesn't have is radar cruise. I prefer the seats in this one compared to my old overfinch.
Post #716639 23rd Apr 2025 10:34am
