Home > Maintenance & Mods (L405) > Front active roll bar bushes
911r44
Hello all
I am chasing a front suspension knocking over bumps, The front lower arm bushes were splitting so have replaced all the lower arms and roll bar drop links.......knocking not resolved grrrr. In fact it's slightly worse now I've driven it a bit.(I don't think I've achieved the very high torque needed on the drop links. Difficult to hold the Torx bit in place!)
I have lateral movement on the sway bar, the whole bar basically slides left to right in the bushes, maybe a cm or two. It needs a bit of a shove to move it, but it does move. I've read another thread here that suggests that's not normal but want to double check. Does anyone else's bar move laterally? The way the bushes and bar mount, it looks like it might be designed to move sideways a little.
So, is this movement normal?
Thanks in advance,
Post #716662 23rd Apr 2025 7:29pm
fisha
No, I dont think sway bars should move side to side. Perhaps a little bit doe to flex of the bush, but not sliding through the centre hole of the bush. V8 or else ...
Post #716699 24th Apr 2025 8:30am
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
I had a knock over bump so had all the 4 arms replaced and the sway bay bushes. No more knock. The bar bushes are cheap relative to the arms so it's not a big ask to change those out at the same time.
Post #716731 24th Apr 2025 5:18pm
JamboM3
The D Bushes going will result in some pretty annoying and loud knocking noises, even creaking too.
I replaced mine after chasing a knock and it's silent now. Was determined because I had lateral play where it would mostly knock on O/S then randomly transferred to the N/S
Post #716780 25th Apr 2025 3:07pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
After you replace the suspension components, take a look at the engine mounts and front struts. My final clunks under acceleration were the torn engine mounts, and on bumps were he struts. Both replaced by me in the driveway. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #716781 25th Apr 2025 3:18pm
