![]() | Home > Maintenance & Mods (L322) > Suspension message 30 MPH |
| JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 310
They did fit a genuine one, although price wise they're a lot more expensive than aftermarket. |
| Jason66 Member Since: 02 Mar 2023 Location: Guildford Posts: 18
Should the suspension make any form of hissing noise under normal operation? I have had the 30mph fault, seemingly triggered at quicker speeds, and had a journey that was less than a mile thankfully, on the bump stops. It cleared when I switched the car off and on again. I was grateful to see this topic at the top of the list! One of my front struts makes a loud hissing and the car wont go up to off-road height so I was thinking split bag? 2012 Westminster Aintree/Ivory 4.4TDV8 |
| Full-fat-Lance Member Since: 06 Feb 2022 Location: Essex Posts: 153
Yep, you’ve got a split bag. |
Figured as much. Thank you for confirming. I’m going to look at the date on the shock but I think they may be original and will therefore be past their best. There was no suspension work showing in the history.
| Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238
It is best to replace both sides, but, check the date on the non leaking bag 'just in case' it has been replaced. My front offside failed recently and was found to be 18 years old ! Checked the other side, it is the same age, so it will be replaced soon. As for OEM, everyone has a different choice. As my originals were Dunlop and lasted 18 years, I went for the same again. Shop around, to find the best deal, there are quite a few good suppliers around.
Thanks for this. Will be taking a look at them this afternoon. I’d imagine they’re pretty old and so will replace both if so. 2012 Westminster Aintree/Ivory 4.4TDV8 |
| All times are GMT |
