Home > In Car Electronics (L322) > Denso touch screen issue please help
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Think I have got to the bottom of this issue I have with my infotainment system my IID tool has said the following faults are present today:
AAM AUDIO AMPLIFIER U3000-55 (2F) control module system programming failure is not configured
ACM AUDIO SYSTEM UPDATE AVAILABLE
ASSEMBLY (F113) new update available
ASSEMBLY (F188) new update available
Is this a job for the stealers of is there any other option.
Cheers
Jay Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #450489 10th Sep 2017 9:12pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
You may need to check the mmm firmware on the secret code screen, 1030 or above.
Instructions on page 166 of the gap manuel.
Worth a look. Thumbs Up
Post #450669 12th Sep 2017 7:03am
jaysta10k
After speaking with Pat at Gap Diagnotics recently due to an error code relating to a module reflash over a series of 3 days and a number of emails and even a reflash of the ACM module I still have the problem we have tried everything but the electrical gremlin stills exists but upon seeing that another member had a very similar issue and he replaced the headunit touchscreen to eradicate it. So here goes I will purchase a touchscreen fingers crossed this sorts the issue! 👍😜 Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #450919 14th Sep 2017 3:55pm
jaysta10k
Thanks for all the help guys it turned out I had a faulty touch screen headunit came today fitted this evening all good 👍 Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #451047 15th Sep 2017 9:36pm
MariusRR
Norway 2003 Range Rover Vogue 4.4 V8 Oslo Blue
Revival of an old post, but did you order just the screen and that sorted it? Have same issue here
Post #716850 26th Apr 2025 6:21pm
