![]() | Home > In Car Electronics (L322) > Did all vogues in 2011 have dual screen or am I dumb? |
JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 250 ![]() ![]() ![]() |
After a couple of hours of googling, the one I need for my 2012 VSE is BH42-10E887-RG
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
you might find that the CCF will have to be adjusted as well ... ... - .- -.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
https://www.fullfatrr.com/forum/topic55729...=dual+view
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 785 ![]() ![]() ![]() |
When I've tried out dual view on mine, it says on the screen to press TV to switch to dual view which works very well. Not sure if others are the same. |
New dual view unit arrived today courtesy of eBay. The screen was typically smudged where fingers have worn away the "protective" coating. I've removed the outer frame, which is 6 small Philips screws and that's revealed the screen in its full entirety.
An update...
Patrick has since revoked earlier guidance and you don’t need to swap over the screen. The full head unit can be installed and configured using GAP apparently. |
That’s what I remembered reading somewhere, as you would have also needed the buttons from the new screen too…. If indeed you had to do it that way.
Having stripped the new dual view unit in readiness to swap the screen over, the buttons etc could me with it. It’s a ribbon cable jobby into the head unit itself.
