Home > Maintenance & Mods (L405) > front control arms
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
fisha wrote:
Good job. I think this is a job thats creeping up on me in the near future. Knowing my luck, I'll probably find it a pain like you did.
i think i may of caused some of the problem myself as i removed both of the control arms at once (still new to range rovers ) so i think if you only remove one at a time you wont have as much trouble as me ,going to be doing the other side in the next few days so will let you know
Post #716786 25th Apr 2025 7:02pm
will308f
Did mean to ask to those who have replaced there control arms did you use new bolts ? I didn’t but have got new nuts on order as they got trashed getting them off
Thanks
Post #716809 26th Apr 2025 6:48am
will308f
ok just finished the other side this time i did one control arm at a time still a faff but didnt get the same issue as i did on the other side Thumbs Up
just been for a drive around and i have to say at the mo its a bit creaky but im hoping it will go away as it settles he says with fingers crossed Laughing
Post #716983 28th Apr 2025 2:51pm
kevinp
Did you remember to tighten the bolts with the weight of the car on the ground and not in the air. Shouldn't creak really.
Post #717001 28th Apr 2025 5:20pm
will308f
i jacked up the hub to normal ride height was this no good ?
Post #717004 28th Apr 2025 6:02pm
Gremlin500
Yes, that’s OK, as far as the car is concerned it’s at normal ride hight.
It’s to prevent torsion (twisting) of the rubber bushing being pre-tensioned by the weight of the car, causing the bush to fail early. V6 Vogue - “Less is More” - less to go wrong!
Post #717008 28th Apr 2025 7:06pm
will308f
ok right got something correct then lol
Post #717009 28th Apr 2025 7:07pm
will308f
been out in the old girl today and yes no noise no creaking Thumbs Up brills think it must of just sorting it self out all good now ....wife happy order now restored Rolling with laughter
Post #717086 29th Apr 2025 4:54pm
