Home > My Range Rover > My 2012 Vogue SE
JonnyCJ
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Sumatra Black
My 2012 Vogue SE
About time I started a dedicated thread to record what I’m doing on my VSE.
Needless to say I absolutely love it and it has come with it’s fair share of things to sort, but I do love to get my knees deep into a project.
So far I’ve;
Installed DAB+
Had the underside totally wire brushed, rust proofed and all cavities, including sills and subframes liberally sprayed with Dynax S50
Partially restored the seats - updates to follow
Installed a new final stage resistor. I’ve found that a used Sitronic OEM from eBay works much better than the cheap aftermarket
Had all new genuine idlers, pulleys, tensioner and belts fitted to the front of the engine
Installed a genuine Land Rover water pump for good measure
Changed the oil and filter (Smith & Allan)
New genuine Land Rover fuel filter
Other projects to follow !
Post #717178 30th Apr 2025 6:43pm
JonnyCJ
Todays’s task involved the receipt of my new totally rust free tailgate. This arrived on a pallet and is in excellent condition. It did however come with a clear glass, so I’ll need to swap over the screen from my old tailgate once I’ve sorted this one out.
First job was to dose the whole of the inside of the tailgate with Dynax UC. I had this so it was literally dripping out of every seam and crevice. It sets like candle wax, so doesn’t attract dirt and is non-sticky.
The screen removal tool arrives tomorrow, so hopefully I’ll be able to get the glass off.
Post #717179 30th Apr 2025 6:53pm
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Not a bad idea there Jonny putting all your jobs to do in one place, save me jumping from one thread to another lol.
Be careful removing the rear screen, I have no idea how easy it is to do and without breaking it. Maybe worth considering buying some tinted film and doing it that way, better to be safe than sorry. I tinted my old Saab with film years ago, very easy to do and lasted right up until I sold it and beyond.
Post #717273 2nd May 2025 12:00pm
mjdronfield
I paid a windscreen fitter to swap mine over when I did similar on my TD6, years ago.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #717278 2nd May 2025 1:43pm
JonnyCJ
Been busy recently on various jobs, including the interior. Yesterday I stripped out the blower motor to check why I wasn’t getting a cooled bum. There was some very slight cooling but not what I’d expect.
Turns out the tube had the usual cracks, so repaired them with fibreglass on the inside and outside of the crack and then fabric tape over everything, as the PE plastic doesn’t take any glue/resin products too well.
Popped it back in and all nice and cool.
Pleased that the Peltier units are working, but now means I have 2 Peltier units on the shelf.
Also did some more interior painting and painted both glove box lids with Scratch Doctor Ivory NG. I’d done them previously with a sponge but never got a finish I was happy with, so decided to give the skip find Sealey spray gun a go. It was all gunked up, so stripped it down, cleaned it up and got some very nice results. Did the driver’s side seat valance as well and gave the control panel a blast of Matt black, after masking off.
Still some work to do on the seats - I’ll probably swap passenger and driver over, bit looking much better than when I started.
The filters at the front of the front seats were filthy - not sure they’ve ever been cleaned. A wash with some shampoo had them a lot cleaner. They’re still wet in the second pic, so look a bit dirtier than they are. These can be easily accessed by lifting the front of the seat right up and poking your head in. You’ll see them there and they just unscrew and screw in again. A very easy and worthwhile job.
Post #718142 18th May 2025 12:10pm
JonnyCJ
Door handle cable change
Today's little job was changing the outer handle release cable. The cable hadn't snapped, but the plastic sleeve that locates into a bracket just by the lock had deteriorated over the years, so there was no resistance.
Simple job in the end, took about 30 mins start to finish and £7.89 for a cable from eBay made it a cheap one as well.
The door handle now opens beautifully, which is very handy when you want to get into the car.
Post #718411 23rd May 2025 12:56pm
JonnyCJ
Today’s job was replacing the Peltier module on the driver’s seat. Simple enough job with a bit of soldering to save crimping new spade connectors for the block connector.
I sourced the new unit from AliExprsss for about £27 delivered. For those of you concerned about buying Chinese products, here’s a pic of the old failed unit.
I now have a nicely heated and cooled driver’s seat base and back. What I originally thought was cooling was in fact just air blowing through the perforations.
Post #718506 24th May 2025 7:14pm
rob8420
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Stornoway Grey
Always nice to see some jobs getting done, especially that you didn’t know about.
I’ll have to look at the filters on the front seats, I’m sure they will have never been cleaned. 2011 FFRR Vogue SE Stornoway Grey
Post #720551 29th Jun 2025 1:56pm
JonnyCJ
The cooled seats have been a godsend in the current hot and humid weather, so well worth doing.
I took a day off today as her indoors and the boy are in Cornwall and it gave me an opportunity to do some Rangey stuff.
Back seats out and stripped down, ahead of refurbing the bases.
Taking the base apart revealed this mess. Why do they let kids in the back of cars ? It’s beyond me.
What was more disappointing was that the crisps were cheese and onion, at least eat salt and vinegar.
Still, it was a welcome mid job snack Laughing
I’ve thoroughly cleaned the base, removed a lot of the creasing with a heat gun and filled the cracks that didn’t come out. Tomorrow will be sanding down, then spraying to hopefully return to almost as new.
I’ve found that spraying produces a much better finish than using a sponge.
2/3 base before
During
Post #721527 18th Jul 2025 6:20pm
JonnyCJ
Rear seats finally finished and back in
Post #722105 30th Jul 2025 6:45pm
dhallworth
Those rear seats look great, what a transformation.
Post #722117 30th Jul 2025 11:19pm
toby1
Lovely job. 2012 Vogue TDV8 in Aintree green over sand
Post #722123 31st Jul 2025 7:47am
JonnyCJ
Also recently completed is the tailgate swap over. I now have a totally rust free rear, aside from some light surface corrosion on the front of the rear arches.
Post #722127 31st Jul 2025 8:41am
