![]() | Home > Technical (L322) > Rear suspension looks collapsed (but isn't!) |
tspd Member Since: 13 May 2024 Location: London Posts: 70 ![]() ![]() ![]() |
Hi all,
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1553 ![]() ![]() |
Is it possible that the arms have flipped over on the sensors to be the wrong way round when you’ve been doing work ? V8 or else ... |
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 77 ![]() ![]() ![]() |
My vehicle did very similar, but lowered at the front and raised the rear. It turned out to be a faulty height sensor. Found the culprit by removing each sensor arm in turn, and moving them throughout their range whilst monitoring the voltage on the iid tool . The voltage should be a smooth transition with no spikes. |
SeldomSeenKid Member Since: 24 Jan 2024 Location: Glasgow Posts: 85 ![]() ![]() ![]() |
Wouldn't a faulty height sensor not show up on the 4x4 display in the head unit?
You would think, but it did not.
