![]() | Home > Technical (L322) > Is a Bosch or Denso Alternator better? |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2755 ![]() ![]() |
If I had the option then I would choose Bosch over Denso because I have found that Denso fit avalanche diodes as the rectifiying diodes for over voltage protection rather than desiging a regulator that shuts-down when over-voltage. However I don't know if Bosch do the same but I do know that some alternator manufacturers don't use avalanche rectifier diodes. The reverse conducting threshold voltage of avalanche diodes reduces with usage causing them to eventually short-circuit to ground at normal voltages, flattening the battery very quickly. L405 D350 SE Carpathian Grey D5 19" rims |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 787 ![]() ![]() |
I would get the cheapest/most convenient of those 2. I would expect either to outlast a nearly 20 year old car.
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 490 ![]() ![]() ![]() |
I used a lot of Denso ones over the past few years and never had one back so far. |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1867 ![]() ![]() |
Denso are the OE supplier to JLR, if it's lasted this long, I'd buy another |
bigfatbloke Member Since: 08 May 2018 Location: London Posts: 40 ![]() ![]() ![]() |
Thanks for the replies gents.
JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 295 ![]() ![]() ![]() |
Just bought a Dan1110 Denso from AUTODOC for my 2012 4.4 TDV8. The price fluctuates daily, so I popped it in my basket and watched the price for from £230 to £250 to £278 and then down to £218.
