![]() | Home > Technical (L405) > Restricted performance, Engine won't turn off... |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
Probably way off base. but "running on" was a sign of timing being over advanced. Could it possibly be an intermittent error with the crank position sensor causing a timing shift?
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2722 ![]() ![]() |
Does your IIDtool's configuration show 2 types of faults set to show? I can't remember which one it is that isn't on ex factory but needs to be set on to show all faults. L405 D350 SE Carpathian Grey D5 19" rims |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8704 ![]() ![]() ![]() |
Thanks for taking the time to post chaps....
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 188 ![]() ![]() ![]() |
It is called "pending faults" and by default are not shown. |
Graeme and Jimmy,
You might want to check the PCM status to see if there is a later version that might have a bug fixed. L405 D350 SE Carpathian Grey D5 19" rims |
Dartanjang Member Since: 03 Nov 2022 Location: Vasteras Posts: 17 ![]() ![]() ![]() |
I had exactly your phenomenon. It was an EGT-sensor that started to act up. It was gradually deviating and randomly reading a temperature that was too much off compared to the others, which triggered a plausibility check.
Graeme, that's a good call, thanks for your thoughts, much appreciated...
For me it was Bank 1, Sensor 2. The easiest one to get to. A couple of threads about it:
Thanks a lot... |
