Home > Technical (L322) > 2011 5.0 N/A no crank after engine replacement
peanutpckrupper
United States 2011 Range Rover HSE 5.0 V8 Santorini Black
Replaced the engine in my 2011 due to timing chain failure and now I have a no crank condition. When I press the start button the ignition will come on sometimes for 1 second then shuts off, sometimes it just stays on but still no crank.
I've metered out all of the fuses and verified they are ok, double checked all of my engine wiring harness connectors and they're all connected. I'm aware of two grounds for the engine, one attached to the oil pan and one attached to the rh cylinder head. Both of those have been cleaned and checked out fine.
I'm not really sure where the no crank is coming from and I'm stumped at this point. If I put power to the starter the engine will crank but no start. I do still have the front suspension and steering rack disconnected, not sure if that matters?
Any help would be appreciated!
Post #717486 6th May 2025 2:28pm
dhallworth
Are your brakes all bled out properly?
When the car wants your foot on the brakes it’s looking for brake pressure, not just the brake switch to be activated so if you’ve not bled the brakes and have zero brake pressure you’ll see the exact same symptoms you’re describing.
Try pushing much harder on the brake pedal and then cranking and see what happens.
Did you use the wiring loom from your original engine or the replacement engine? It could be the new loom is different and not compatible with your car.
Have you checked the connections to the starter motor? If you short out or install a piece of wire with a switch on it between the terminals on the starter does the engine crank then?
There’s so many variables when a car has had this much work done to it unfortunately.
Post #717487 6th May 2025 2:32pm
peanutpckrupper
I didn't disconnect the braking system, but I'll try pumping up the brakes to see if that helps. Thanks!
Post #717488 6th May 2025 2:33pm
dhallworth
No worries, just edited my original post with a few other things too. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #717490 6th May 2025 2:35pm
peanutpckrupper
Gotcha I see the edits. I used the wiring harness from the original engine and the engine does crank if I apply 12v to the starter signal wire but still does not start.
Post #717491 6th May 2025 2:39pm
peanutpckrupper
dhallworth you're my hero, I've moved on to a crank no start now. That's way easier to investigate.
Post #717493 6th May 2025 3:03pm
dhallworth
Brilliant, happy to help.
Check you’ve got the crankshaft sensor plugged in if it’s doing crank no start.
If you’ve got diagnostics you’ll also be able to see if the ECU can see the engine spinning over by monitoring the rpm in live data.
Post #717497 6th May 2025 4:14pm
peanutpckrupper
It starts on starting fluid, I need to investigate the fuel system.
Post #717498 6th May 2025 4:27pm
peanutpckrupper
Well it kinda starts now but I didn't do anything different from before. Long crank, runs for a second or so then dies. I can rev it up just fine while it's running but it always bogs out after a second or two. The only codes I'm seeing are related to the ride height sensors which aren't hooked up. My obd scanner shows ~2100 psi of fuel rail pressure, drops into the ~2050 range while cranking and running.
I have it on a battery charger and have my jump box hooked up, but does the car need to see voltage from the alternator to stay running? I don't have the serpentine belt installed yet.
Post #717514 6th May 2025 7:13pm
dhallworth
That sounds very low for fuel pressure. I'll need to check mine at some point to be sure though. If the fuel pressure isn't building pressure properly then it won't try and fire.
Are you using the fuel pumps and injectors from the donor engine? I wonder if there's an injector that's stuck open or a knackered fuel pump causing it to not build pressure properly.
Surprised you don't have a low fuel pressure code though.
Post #717520 6th May 2025 8:22pm
dhallworth
Update - looks like your pressures are about right when cranking going by this thread here:
https://www.jaginfo.org/threads/aj133-hpfp.114132/ 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #717521 6th May 2025 8:24pm
peanutpckrupper
Turns out this is one of those cars where you need to have the airbox fully installed for it to run Banging Head
So the gist of it is: Put it at least most of the way back together and step on the brakes hard.
Thanks dhallworth!
Post #717524 6th May 2025 8:43pm
dhallworth
Ahh, did you not have the MAF sensors connected? That would explain it!
Is she running well now?
Post #717525 6th May 2025 8:46pm
peanutpckrupper
The sensors were plugged in, but I didn't have the center airbox installed and hooked up to the throttle body. Running all good now! Time to reinstall everything and take it out on the road for the first time.
Post #717526 6th May 2025 8:48pm
