| | Wheel speed sensor resistance test to check functionality? |  |
 I've just changed the reluctor rings and speed sensors on a 2012 L322 as rings had swolen and were stuck in the hubs.
The rear sensor is now working fine but the front sensor is still reading zero.  As there.were two supplied I've changed out first one for the other new one, no difference in the Live data reading.
 I've pulled the multi plug on the ABS module and continuity checked from there to the female socket behind the wheel and that is fine... which leads me on to...
 If I rotate the hub should I get a fluctuating resistance reading across the speed sensor?
 I'm wondering if the ebay speed sensors could be an issue and if there was a way to check them without sourcing another one?
 Otherwise it's the ABS module but as the ABS system and vehicle in general  was fine when it drove into the workshop I'm hoping its the speed sensor.
 Any ideas would be great
